McLaren MCL33
matt_s
matt_s
Re: McLaren MCL33
gridwalker wrote:
11 May 2018, 11:47
I believe it is down to widening the gap between the pylons in order to maximise flow to the cape.
Moving the wing pylons wider increases the surface area of the nose. This creates space above the minimum regulated requirement at the nose tip, so it is better to reduce the impact by adding ducts. Although not as good as free flow air, the overall volume should be increased.
I'm not convinced the pylons are wider than the RBR. They're not set any wider relative to the neutral section of the wing.
f1rules
f1rules
621
Re: McLaren MCL33
i think scarbs is wrong
makecry
makecry
19
Re: McLaren MCL33
f1rules wrote:
11 May 2018, 12:05
+1.
dmjunqueira
21
Re: McLaren MCL33
This car looks mean with the new nose!
Re: McLaren MCL33
All three ducts are divided by the looks of it?
mwillems
45
Re: McLaren MCL33
Nonserviam85 wrote:
11 May 2018, 10:10
mclaren111 wrote:
11 May 2018, 08:39
Thunder wrote:
10 May 2018, 18:49
... and i still don't know where that S-Duct exit is... :?:
Also very surprised that there is no S-Duct !! :o :o
I think I saw some exits painted in black on the back sides of the nose but this doesn’t look like a standard S duct configuration
Are the two side inlets pushing the air under the cape/canard with the central for driver cooling?
Looks like the S Duct as we know it has been demised on the Mclaren?
-Bandit
matt_s
matt_s
Re: McLaren MCL33
makecry wrote:
11 May 2018, 12:09
f1rules wrote:
11 May 2018, 12:05
+1.
So - as per my original quandry - where do they vent to?
f1rules
f1rules
621
Re: McLaren MCL33
i think the two outer push air below you can easily see they are angled down inside, the central im not sure, but im quessing above
Re: McLaren MCL33
hmm i'm mistaken though, no engine cover changes. i think i got fooled by the different (vertical) sidepod turning vanes, which were more or less 'non existant' in baku.
Re: McLaren MCL33
mwillems
45
Re: McLaren MCL33
f1rules wrote:
11 May 2018, 12:15
Spitbaling here, but...
It does look that way, and it would make sense. It seems Mclaren may be putting all their focus on the floor/diffuser now. Would be nice to get a shot under the car, although that generally means crashing, so I can wait for that...!
This also explains a little more why they went for that specific rear suspension setup. With more air passing through that area the gains from greater aerodynamic efficiency are a little more pronounced.
-Bandit
Re: McLaren MCL33
makecry wrote:
11 May 2018, 01:34
Is there any change to the engine cover? Look same as it was in Baku for me but I might be wrong.
PU Cover is tighter
McL-H
McL-H
-6
Re: McLaren MCL33
diffuser wrote:
11 May 2018, 14:29
makecry wrote:
11 May 2018, 01:34
PU Cover is tighter
No, it’s the same.
ALO_Power
ALO_Power
Re: McLaren MCL33
McL-H wrote:
11 May 2018, 14:54
diffuser wrote:
11 May 2018, 14:29
makecry wrote:
11 May 2018, 01:34
PU Cover is tighter
No, it’s the same.
Many people are reporting it is tighter, mostly at the back (before coke-bottle). We need some good pictures in order to compare since angles and the whole body in bright orange makes it tricky.
BrunoH
BrunoH
Re: McLaren MCL33
im starting to wonder if the duct under the nose is ducting some internals at the back.... its very odd they have the opening but then no real nose S-duct...
