Give up man, people enjoy thinking Alonso is some sort of narcissist who can´t be a professional... despite history
You may be right. They may have chosen not to deploy full sustained power all the way down the back straight.Juzh wrote: ↑27 Aug 2017, 23:07On his pole lap In china for example, hamilton did 328 kph on the start/finish straight and he did 329 kph on the back straight, which is 3 times the length. Very clearly they do not deploy at the same rates for those 2 stretches do they? There's only one reason why that would be the case and that is the fact they can't do it at max output over the whole lap.henry wrote: ↑27 Aug 2017, 18:11can I ask which of the numbers I used you disagree with? I think they have more than enough electrical energy to achieve full deployment for WOT over a full lap. I didn't include the charging they can do under part throttle which would provide even more energy.
Do you have some examples of the variation in acceleration rates?
http://i.imgur.com/zvPWQqE.jpg
http://i.imgur.com/VYWjeuR.jpg
"...History."Andres125sx wrote: ↑28 Aug 2017, 11:13Give up man, people enjoy thinking Alonso is some sort of narcissist who can´t be a professional... despite history![]()
That quote is wrong.ZakB wrote: ↑27 Aug 2017, 23:33
I also doubt it.A maximum of 4MJ per lap can be returned to the MGU-K and from there to the drivetrain - that’s ten times more than was possible with KERS, the ‘bolt-on’ recovery system ERS replaced in 2014. That means drivers have access to an additional 160bhp or so for approximately 33 seconds per lap.
Can you please point me to the relevance of what Kocinski did when we´re talking about Alonso? Heck that´s not even F1J.A.W. wrote: ↑28 Aug 2017, 11:39"...History."Andres125sx wrote: ↑28 Aug 2017, 11:13Give up man, people enjoy thinking Alonso is some sort of narcissist who can´t be a professional... despite history![]()
..of 'hissy fits'?
Or like..
'No way, he'd never choose to do that, & not now, since he never has' ?
I recall a 'highly strung' motorcycle World Champion who was once.. so annoyed by his machine..
..that he held it WOT in neutral.. revving it out,' til it failed catastrophically.. John Kocinski..
Your post wasn't clear.. hence my question marks.. which idea is it - that you are suggesting?Andres125sx wrote: ↑28 Aug 2017, 11:53Can you please point me to the relevance of what Kocinski did when we´re talking about Alonso? Heck that´s not even F1J.A.W. wrote: ↑28 Aug 2017, 11:39"...History."Andres125sx wrote: ↑28 Aug 2017, 11:13
..of 'hissy fits'?
Or like..
..that he held it WOT in neutral.. revving it out,' til it failed catastrophically.. John Kocinski..![]()
Del Boy wrote: ↑28 Aug 2017, 00:20The technical regulations state that the PU is 100% controlled by the throttle. Article 5.6 is very clear, it's only about where the energy comes from!Zynerji wrote: ↑27 Aug 2017, 04:24I'm completely against GPS tuning to these items.
Hybrid deployment should be directly related to throttle deployment, not a track awareness via technology.
How is this kind of control scheme NOT considered a driver aid?
What would happen in reverse? What if it gave way too much in the wrong place?
The power deployment should be under the drivers control 100% of the time. Not a computer.
But that's not full power mode, that's self sustaining mode.
Tell that to guys that run the official F1 site.henry wrote: ↑28 Aug 2017, 11:49That quote is wrong.ZakB wrote: ↑27 Aug 2017, 23:33
A maximum of 4 mJ can go from the ES to the MGU-K. There is no limit to the number of J that can go from the MGU-H to the MGU-K. So if the MGU-H makes 60 kw the ES drains at 60 kw and can do so for 66 seconds.
This is happening on most tracks in all conditions, wind direction is irrelevant here. I say most tracks because on some tracks they do in fact have enough energy for max deployment over the lap (thinking monaco specifically).henry wrote: ↑28 Aug 2017, 11:37You may be right. They may have chosen not to deploy full sustained power all the way down the back straight.Juzh wrote: ↑27 Aug 2017, 23:07On his pole lap In china for example, hamilton did 328 kph on the start/finish straight and he did 329 kph on the back straight, which is 3 times the length. Very clearly they do not deploy at the same rates for those 2 stretches do they? There's only one reason why that would be the case and that is the fact they can't do it at max output over the whole lap.henry wrote: ↑27 Aug 2017, 18:11
However there is another possibility. The normal wind direction in Shanghai in April is ESE. The average wind velocity is 18 kph. So the Mercedes may have been experiencing a slight tailwind on the start straight and a rather higher headwind on the back straight. So the peak wind speeds may have been 325 vs 335, which is a power difference of around 50 kw.
Those numbers are only for illustration. I don't have the actual wind direction and strengths at the circuit and anyway they may well be modified by the grandstands.
Anyone can be wrong. In this case it's whoever wrote that piece for formula1.com.ZakB wrote: ↑28 Aug 2017, 13:03Tell that to guys that run the official F1 site.
https://www.formula1.com/en/championshi ... stems.html
sometimes the truth is the most enjoyable construct.Andres125sx wrote: ↑28 Aug 2017, 11:13Give up man, people enjoy thinking Alonso is some sort of narcissist who can´t be a professional... despite history![]()
ZakB wrote: ↑28 Aug 2017, 15:04
It's painful to watch.
https://www.facebook.com/Formula1/video ... 958748654/
