Red Bull RB20
Farnborough
Farnborough
101
Re: Red Bull RB20
Owen.C93 wrote:
03 May 2024, 14:59
I think Pirelli set a 2deg limit on the rear, 3.5deg on the front anyway.
You’ll want less for traction probably.
Yes, think they (Pirelli) put more restriction on rear during early V6 phase with Mercedes giving problems in failing inner rear shoulder .... from recent memory.
It does seem that the 2022 rule set was responded to by RB with using notably conservative rear camber from the start, with others now appearing to take this on board in looking at race tire life prospects.
Hoffman900
Hoffman900
211
Re: Red Bull RB20
The problem with looking at contact pattern during parc ferme is the car is unloaded from aero stand point.
I think it’s reasonable to assume the cars are making at least as much as they weigh, at some speed.
Stu
Re: Red Bull RB20
Owen.C93 wrote:
02 May 2024, 13:02
Williams have similar features. Hasn’t been discussed much though.
https://pbs.twimg.com/media/GKX1aPqWMAA ... ame=medium
I was going to suggest Williams, the chassis side (above the floor entrance is a similar shape (getting wider as it moves down).
A lateral contraction is a contraction.
Farnborough
Farnborough
101
Re: Red Bull RB20
Hoffman900 wrote:
03 May 2024, 17:50
Yes, understand this and I agree.
However, looking at them right from the outset in starting 2022 regulation, they seem to have designed around very low static camber initially, also when loaded to extreme lateral and really sunk into it's vertical travel, the RB appears to go /allow into positive camber without real detriment.
In comparison to others, that started 2022 with more "traditional" static camber, they all seem to have followed more to this direction.
It would appear to bleed off at the limits grip more gently by letting the tire roll over more onto outer sidewall, as comparison to higher absolute peak grip with more rapid and unpredictable release in extremes.
Also to make, ultimately, more use of tread gauge across the whole tire footprint, by potentially favouring longitudinal traction, less inner shoulder wear etc than greater camber allows.
It may even allow the chassis to be pivoted by rear movement under less aero load (slow corner at sharp angle) by fomenting rear grip elasticity in opposition to reliance, and subsequently, higher taxing of front tire and axle mechanical grip in that steering phase. Requires more driver acceptance of progressive rear movement and use of that characteristic to execute though.
KimiRai
KimiRai
257
Re: Red Bull RB20
Emag
Emag
84
Re: Red Bull RB20
KimiRai wrote:
16 May 2024, 18:54
The floor edge looks interesting to say the least. Is it something they have run before or is it new?
Cs98
Cs98
Re: Red Bull RB20
Emag wrote:
16 May 2024, 19:01
KimiRai wrote:
16 May 2024, 18:54
Think it's the same as before. I can't see any changes on the car as shown.
kediown
58
Re: Red Bull RB20
Upgrade weekend in Imola, including a new front wing and floor at Red Bull.
As far as I see the upgrades aren't fit yet
Emag
Emag
84
Re: Red Bull RB20
Cs98 wrote:
16 May 2024, 19:05
Emag wrote:
16 May 2024, 19:01
KimiRai wrote:
16 May 2024, 18:54
Yeah, on a second look it seems like its the same. It was the first time I saw a close-up view.
KimiRai
KimiRai
257
Re: Red Bull RB20
lio007
316
Re: Red Bull RB20
The central section looks like a "diffusor in a diffusor" to me :)
In Comparison RB19:
230
Re: Red Bull RB20
Maybe the car is just shinier, but to me the parts look like they have made lighter.
The teams use different techniques to set up and mold their carbon composites.
Redbull have an interesting layup int he undercut of the sidepod. The fibers look as if they were very fine and randomized. Compared to sone sections that have the checkered pattern. Further still, the finish looks like it produces very thin and sharp components.
The new ferrari upgrades are also very thin pieces. Compared to a williams and alpine that have quite chunky and blunt bodywork.
FW17
169
Re: Red Bull RB20
lio007 wrote:
16 May 2024, 22:09
In Comparison RB19:
https://pbs.twimg.com/media/F9ZkjC2WYAI ... name=large
https://pbs.twimg.com/media/F9ZkjC0XgAQ ... name=large
Mclaren diffuser looks much larger than the Red Bull because of the skinner gearbox
Andi76
Andi76
431
Re: Red Bull RB20
FW17 wrote:
17 May 2024, 05:22
lio007 wrote:
16 May 2024, 22:09
In Comparison RB19:
https://i.imgur.com/zC6anNV.jpeg
I think the angle here deceives your perception somewhat. Both diffusers rise relatively similarly after the plank and are relatively similar in size.
FW17
169
Re: Red Bull RB20
Andi76 wrote:
17 May 2024, 06:58
FW17 wrote:
17 May 2024, 05:22
lio007 wrote:
16 May 2024, 22:09
In Comparison RB19:
RB 20 gearbox seems to be same as RB 19
