Vodafone McLaren MP4-27 Mercedes
Pup
Pup
50
Re: Vodafone McLaren MP4-27 Mercedes
5.8.4 Once the exhaust tailpipes, the bodywork required by Article 3.8.4 and any apertures permitted by Article 3.8.5 have been fully defined there must be no bodywork lying within a right circular truncated cone which:
a) Shares a common axis with that of the last 100mm of the tailpipe.
b) Has a forward diameter equal to that of each exhaust exit.
c) Starts at the exit of the tailpipe and extends rearwards as far as the rear wheel centre line.
d) Has a half‐cone angle of 3° such that the cone has its larger diameter at the rear wheel centre line.
hardingfv32
hardingfv32
Thanks
Another challenge to the Conda Effect. Since the channel is round, the Conda Effect caused by the interaction of the exhaust flow and the channel is greatest at the bottom of the radius and progress to zero as you reach the side of the channel (90 deg). I am assuming that that focus of the Conda Effect is in vertical plan with the goal to bend the flow downward.
Brian
Carlo's
Carlo's
McLaren is checking airflow around diffuser:
Shrieker
They got a new(slightly different let's say) config at the exhaust bulge ?
-Atatürk
beelsebob
beelsebob
85
Shrieker wrote:They got a new(slightly different let's say) config at the exhaust bulge ?
Do they? I don't see it, can you point out what you're seeing as different?
Crucial_Xtreme
Crucial_Xtreme
404
I don't think so, I believe it's just the angle the picture was taken.
Right click>view image
Banki
Banki
Has somebody got pictures about the developments?
shelly
shelly
136
hardingfv32 wrote:Thanks
Brian
What do yo u mean when you say "challenge"? The Coanda effect applies to round jet also.
twitter: @armchair_aero
Shrieker
The slits looked different to me, though it could be the angle too as Crucial_Xtreme has pointed out...
On a side note, the inner part of the rear right looks chewed to me, uneven tyre wear or exhaust burn ?
-Atatürk
thestig84
thestig84
I would say just rubber pick-up in the pitlane.
Hangaku
Crucial_Xtreme wrote:Image
What's going on with the rear wing there? Measuring airflow?
Edit: Image added back again due to new page :P
Yer.
astracrazy
astracrazy
31
measuring flow around the front wing too? zoom in and follow down from the M on the mclaren.com decal. Looks like a tube
blokkie
blokkie
astracrazy wrote:measuring flow around the front wing too? zoom in and follow down from the M on the mclaren.com decal. Looks like a tube
Yep , looks like it indeed. Well spotted !!
afiq
afiq
Looks like tire marbles
Hangaku
Inspecting the rear wing further, it does appear to be just the DRS actuator, but it's does appear larger than previous incarnations. The contrast of the image made it look like a flat black "panel".
Yer.
