Mercedes AMG F1 W08 EQ Power +
F1Krof
95
Re: Mercedes AMG F1 W08 EQ Power +
banjo789 wrote:
02 Oct 2017, 14:05
The fundamental design of the cars suspension was built around the trick ride height control that was banned pre-season. That left Merc with a low rear ride height that could not be ‘self-levelled’ and so had to be stiffened to maintain diffuser efficiency and remove the threat of ‘choking it’ over undulations in the track. This has handicapped the setup of the car all season as the engineers hands are figuratively tied behind their backs with certain aspects of the setup.
Unless Merc can find another way of managing the suspensions sensitivity to pitch/roll then the W08 could be the last of the low rake Merc’s as they look for alternatives for next year.
This is logical. I think you're probably right when you say so. Otherwise, it doesn't make sense for them to go opposite of the others, even Sauber has more rake, and they thought they could get away with tricky suspension ride management as you say.
Wroom wroom
djones
djones
Hamilton has said the thinks he knows how the issues can be minimized and wants to try something different in Japan.
He said in the last race they were unable to use the downforce. What that means, I'm not sure??
But I suspect they will maybe run high downforce in Japan and sacrifice top speeds. Like Redbull used to do in the glory days.
JasonF1
djones wrote:
04 Oct 2017, 15:35
That would make for an interesting read. Do you have the link of the article where he said that?
Shaddock
djones wrote:
04 Oct 2017, 15:35
The rear wing used at the last race was a high downforce spec similar to in Singapore. The new aero package that LH didn't run in the race may add a few points of DF so he may be referring to that if they can get the balance right.
djones
djones
JasonF1 wrote:
04 Oct 2017, 17:57
djones wrote:
04 Oct 2017, 15:35
https://www.autosport.com/f1/news/13217 ... sepang-woe
djones wrote:
04 Oct 2017, 15:35
Aero sensitivity could be an issue here. You can't use all available downforce if this downforce changes too much through different ride heights, yaw angles etc.
Shaddock
wesley123 wrote:
04 Oct 2017, 19:50
djones wrote:
04 Oct 2017, 15:35
I don't believe anyone from Merc has said that they have peaky aero like McLaren had a few years ago. It seems to be that the surface temp of the tyre goes out of range (overheats) although the core temperature of the tyre stays in the operating temperature window and this reduces the grip levels.
According to AMuS (I used Google Translate so forgive me if there are mistakes):
-Both Mercedes drivers will run the new aero parts in FP1 at Suzuka.
-According to their wind tunnel numbers the new updates are worth at least a tenth of a second.
-They are worried about the weather prediction, Friday practice sessions are mainly going to be on a wet track, qualifying will be dry, but cool and there will be a significant raise in temperature on Sunday.
-If they're going to have any problem, it's gonna be visible on Saturday (the car has to be prepared for completely different conditions on Sunday). And Suzuka's asphalt surface which is very rough with a lot of grip is going to be problematic as well since their car requires the opposite of that to perform well.
Via @AlbertFabrega
designf1
designf1
73
https://www.motorsport.com/f1/news/hami ... an-961549/
Hamilton is unsure on what they should run with.
Sevach wrote:
05 Oct 2017, 12:31
So guys I got an off topic report about this. I admit this a rather grey area as it about specific hardware on the car, which is according the topic rules. However, it also handles strategy and (laptime) performance.
So let's focus on hardware difference concerning this particular subject. It is allowed to note if the drivers run a different aero package, and also allowed to discuss the physical differences, but let's stay clear from discussing performance differences. So considering that, this is fine.
OO7
OO7
171
From those images, the car is running the older diffuser.
ScrewCaptain27
577
Front upright detail (AMuS):
- Serj Tankian
designf1
designf1
73
