Ferrari F1-75
Re: Ferrari F1-75
LM10 wrote:
24 Mar 2022, 17:12
GrrG wrote:
24 Mar 2022, 12:12
Ferrari's 2022 power unit.
Strange that Ferrari is OK with presenting the PU in it's naked entirety.
They don't have a choice. I don't think you are allowed to block the garages anymore.
A lion must kill its prey.
Re: Ferrari F1-75
vorticism wrote:
24 Mar 2022, 20:37
GrrG wrote:
24 Mar 2022, 12:12
If it is split turbo, I was trying to make sense of why the airbox is so far back. Also, why there seems to be no plenum elbow ahead of the engine, where you might expect the compressor inlet to be. Maybe they've flipped the compressor around. They have many seasons of experience running the inlet over the compressor shaft.
https://i.imgur.com/rzpiB1f.jpg
Another explanation is that it is not split turbo, the compressor is still at the back, and the intercooler position might have been changed.
This intercooler layout is nice. They can lay the intercooler down on the floor and lower the CG.
JPower
JPower
43
Re: Ferrari F1-75
Interesting.
vorticism
323
Re: Ferrari F1-75
25 Mar 2022, 00:16
vorticism wrote:
24 Mar 2022, 20:37
If it turns out to not be split turbo, then the next question is, why do the plenums run down the front of the engine? So in either case it's looking like maybe the intercooler is now low down in front of the engine. Whereas other years it was higher up. In which case, how would they connect a rear mounted compressor to a low front intercooler? The charge pipe would either be routed thru the vee as in previous years, or run along the crankcase. Maybe even two charge pipes either side of the crankcase, connecting to two individual charge coolers leading to the pipes visible in the photo.
𓄀
Re: Ferrari F1-75
vorticism wrote:
25 Mar 2022, 00:51
25 Mar 2022, 00:16
vorticism wrote:
24 Mar 2022, 20:37
If it turns out to not be split turbo, then the next question is, why do the plenums run down the front of the engine? So in either case it's looking like maybe the intercooler is now low down in front of the engine. Whereas other years it was higher up. In which case, how would they connect the connect a rear mounted compressor to a low front intercooler? The charge pipe would either be routed thru the vee as in previous years, or run along the crankcase.
This already sounds so complicated that I have to believe it's a split turbo, to avoid answering your questions about the complicated routing.
Andi76
Andi76
431
Re: Ferrari F1-75
vorticism wrote:
24 Mar 2022, 20:37
GrrG wrote:
24 Mar 2022, 12:12
Mark Hughes said recently it is not split turbo. Interesting to see whether it is or not. Maybe we will find out soon.
It is reported by scuderiafans that Ferrari uses smaller rear break discs to save weight:
https://scuderiafans.com/f1-f1-75-ferra ... ar-weight/
_cerber1
261
Re: Ferrari F1-75
Front and rear
Andi76
Andi76
431
Re: Ferrari F1-75
TNTHead wrote:
24 Mar 2022, 18:02
LM10 wrote:
24 Mar 2022, 17:12
GrrG wrote:
24 Mar 2022, 12:12
Isn't it true that development of the current (ICE part of the) PU's are frozen, so it doesn't matter anymore?
As far as i remember the engine freeze has two homologation deadlines. March 1st and Septembre 1st.
In March the manufacturers had to freeze the ICE, turbo, MGU-H, exhaust system, fuel specification and the engine oil specification.
Untill Septembre they still can make changes to MGU-K, control electronics and engine-store/battery.
Stu
Re: Ferrari F1-75
vorticism wrote:
25 Mar 2022, 00:51
25 Mar 2022, 00:16
vorticism wrote:
24 Mar 2022, 20:37
I was just thinking the same thing, a pair of longitudinal charge coolers would work.
Another alternative is a a ‘semi-split’ turbo with the compressor inside the V. This would compromise the diameter, but if they are using an axial compressor; as opposed to the more conventional radial type, it could work. It still looks as though the oil tank is mounted directly to the front of the engine (visible behind the air pipes).
jagunx51
185
Re: Ferrari F1-75
GrrG
86
Re: Ferrari F1-75
Re: Ferrari F1-75
Re: Ferrari F1-75
Well at least he got it eventually :mrgreen:
LostInTranslation
LostInTranslation
Re: Ferrari F1-75
Vanja #66 wrote:
25 Mar 2022, 18:46
Better late than never, I would say. Read the comments below that post (I cheer strangely on the elegant opinion of a certain RJ) ... but maybe I'm a little bit biased. =D>
Re: Ferrari F1-75
WHY FERRARI’S PUZZLING SIDEPODS....
You can still sense a bit of face saving here :lol:
Ferrari sidepods aren't puzzling anymore than Mercedes or RB.
