McLaren MCL36
proteus
22
Re: McLaren MCL36
When in doubt, make it double size 🙂 But indeed this is very crudely made. Hopefully it survives trough the weekend and doesnt burst in between the seems.
frosty125
frosty125
Re: McLaren MCL36
I wonder if they have made this single large shroud and they will use volume spacers inside to work out the optimal cooling volume then engineer a weight optimised version from there.
Re: McLaren MCL36
Looks like they merged that and the previous carbon duct over the top together, wonder if the carbon fibre one was getting too warm and deforming?
AeroDynamic
349
Re: McLaren MCL36
This is clearly a hastey for-now-solution to get it working this weekend. Hope it allows them to race properly
scheffers
scheffers
Re: McLaren MCL36
their regular welder/constructor must've had a day off
Re: McLaren MCL36
It's very thin wall titanium, you have to skip and stitch around like that to stop it distorting.
scheffers
scheffers
Re: McLaren MCL36
PhillipM wrote:
17 Mar 2022, 14:40
True that, very delicate part to weld, at least they didn't cut it down just to make it look good. =D>
Re: McLaren MCL36
I guess it was welded and shipped before it even cooled down looking at that, given they haven't even run any cleaner over it to take the heat/oxidation marks off, must have been fairly rushed.
Ground Effect
Ground Effect
Re: McLaren MCL36
scheffers wrote:
17 Mar 2022, 14:14
So they got Lando to do it instead?
AeroDynamic
349
Re: McLaren MCL36
Rear Wheel
genarro
genarro
Re: McLaren MCL36
PhillipM wrote:
17 Mar 2022, 14:45
why would you brush down the owidation. you dont have to make it look pretty.you just have to make it functional
AeroDynamic
349
Re: McLaren MCL36
Re: McLaren MCL36
genarro wrote:
17 Mar 2022, 15:00
Contaminants like that give crack formation/propagation areas under heat/stress cycling. Probably not much of an issue for a single race weekend though. You usually scrub off that heavy oxidised area and let it reform it's natural oxide layer instead, they're not that bad as you can see from the weld bead - dark blue in places ain't great but it's heavy straw for most of it which is okay usually. But it's usually done as a matter of course.
SmallSoldier
SmallSoldier
486
Re: McLaren MCL36
Editing my post, initial impression was wrong.
AeroDynamic
349
Re: McLaren MCL36
#AMuS
Different wings
