Nope, no, no, no.mclaren111 wrote: ↑25 Nov 2017, 11:52Amus:
https://imgr4.auto-motor-und-sport.de/M ... 132768.jpg
Interesting aero testing
you are allowed to add winglets around the upper part with max. height of 20 mm
We will allow them to use non-structural fairings around the upper part, which can be no more than 20mm from the main structure.
Cool photo, thanks for that
This creates lift -negative downforce- and a bit of drag. So on its own this is not desirable. What that tells me is that the halo creates substantial issues, either with the airbox or with airflow attachment to the rear (or both), which you can remedy through using winglets like that.Webber2011 wrote: ↑28 Nov 2017, 12:05Cool photo, thanks for that
Can one of you aero guys let me know exactly what that does please ?
Many thanks,
Simon
It’s also about controlling the Halo’s effect on the drivers helemt.turbof1 wrote: ↑28 Nov 2017, 12:40This creates lift -negative downforce- and a bit of drag. So on its own this is not desirable. What that tells me is that the halo creates substantial issues, either with the airbox or with airflow attachment to the rear (or both), which you can remedy through using winglets like that.Webber2011 wrote: ↑28 Nov 2017, 12:05Cool photo, thanks for that
Many thanks,
Simon
What I think is happening, is that the frontal tube of the halo pushes airflow higher up, away from the airbox and bodywork around it. This will rob the airbox of air, which has its impact on the PU, and the rearwing of airflow. So they have to come up with a solution, even though all of this is not desirable.
I knew about that, but somehow i thought they would write the rules making sure the fairing was one piece and covering the Halo, apparently not.
