Care to share the reason for this thought?WhiteBlue wrote:and Ferrari will not agree to have a free choice either.
Marmorini made the point that anything but a 1.8L V6 cannot be developed in time. The claim obviously is rubbish but it shows that Ferrari are lock, stock and barrel sold on the V6 and do not want to see freedom of choice.rjsa wrote:Care to share the reason for this thought?WhiteBlue wrote:and Ferrari will not agree to have a free choice either.
http://www.motorsport.com/news/article. ... 5857&FS=F1andrew wrote:Why is it obviously rubbish?
You can also read my own analysis of Marmorini's claim at viewtopic.php?p=197226#p197226Tim Goss, McLaren wrote:As long as the decisions are made shortly, and I think everyone is in a frame of mind to bring it to a conclusion fairly promptly, (there is enough time). The FIA are working hard at it and I'm sure things will be decided relatively swiftly.
The lopping off of two cylinders was last proposed and executed in 2005 and it turned out to be a totally different engine according to the experts at that time. And those were both port injected NA engines that were on very similar rev levels and internal pressures. This time there would probably not be a single part to carry over. Not even the spark plugs.WhiteBlue wrote:I believe that this is not the true reason for the proposed formula. An optimized 1.8L turbocharged V6 would have a completely different engine technology compared to a NA 2.4L V8. The engine rpms would be much lower in a turbo engine with direct injection. As a consequence the bore/stroke ratio would be different, which necessitates different engine and cylinder blocks, the firing order and the crank shaft would be different including the bearing technology. The loads from inertial forces and working forces would be different requiring a totally new design of pistons and connecting rods. The valve trains and ports would be different in a new formula due to the use of variable timing and lift. This would also impact on the cylinder head design. At the bottom line you see that nothing of the old engine would remain. There is no real option to carry anything over from the old formula into the turbocharged downsized formula.Luca Marmorini wrote:A 1.8 litre V6 engine design would be much easier to adapt from the current 2.4 litre V8s as there is not enough time to design a completely new engine for 2013 with the necessary reliability to have only four units per driver and year.
Luca seems to have a point here as the chassis design of the last 20 years was geared towards V engines with 8-12 cylinders and predominantly 90° V-angle. But again a careful examination reveals that F1 is embarking on a completely new chassis design concept anyway. The new chassis are supposed to have ground effect and side pots which are coming much more forward to protect the driver against side impact. Both points have a huge impact on chassis design. There will be more floor area further forward reducing the necessity to have big front wings. There is also the option to have dedicated venturi channels as used by the the American Champ Cars for many years. The slimmer L4 engine format would be beneficial to a chassis design with venturis. So again it turns out that Marmorini's point is not standing up to examination. It simply masks the fact that Ferrari serve their own agenda like everyone else in F1.Luca Marmorini wrote:A 4-cylinder design would require a complete overhaul of the chassis designs.
WhiteBlue wrote:The lopping off of two cylinders was last proposed and executed in 2005 and it turned out to be a totally different engine according to the experts at that time. And those were both port injected NA engines that were on very similar rev levels and internal pressures. This time there would probably not be a single part to carry over. Not even the spark plugs.
Way to contradict yourself in one page.WhiteBlue wrote:andrew, you conveniently ignore the development time of the last "new" engine. The regulation was decided in December 2004 against firce opposition of BMW. The engine ran for the first time on track in December 2005 after just 12 months. The first race was on March 12th 2006 in Bahrain when all engine competitors turned up with V8s.
Second you are unable to argue any of the points I made.
Sweet Jesus you are infuriating.WhiteBlue wrote:That was a good try! The difference is the aero people in the overtaking working group were more concerned with conserving their own significance to F1 and less with overtaking. It is recorded fact that Brawn advised them about the double diffusor loop hole in the wording of the regulation and proposed a different wording. It was voted down. So one can speculate whether this was by following an agenda or by stupidness. I rather think they simply had the agenda to avoid a physical limit on downforce which had been proposed by the FiA for several years and keep their jobs important for some more years.rjsa wrote:You just saw what the overtaking working group achieved...WhiteBlue wrote:2. So you think all the guys of the engine working group are stupid? Not very convincing.
I believe that Marmorini (Ferrari), Cowell (MBHPE), Simon (FiA), Baretzky (Audi) and White (Renault) are all very intelligent and clever people. They do not make many dumb decisions. Going for more fuel efficient F1 engines with equal performance target will help all of them to improver their employer's brand image with the automotive users. Not such a bad thing to do.
How'd you work that one out? Because I don't answer within 30 secinds? FYI (not that it is any of your business), I am currently catching up on some work and am flicking between my work and F1 Tech as a breather every so often.WhiteBlue wrote:Second you are unable to argue any of the points I made.
No contradiction there. The V10 to V8 transition was a completely new engine and it was done in 12 months. There should really be no problem to to do a new engine again in 30 months. I think you do not understand what we have been talking about.Scotracer wrote:WhiteBlue wrote:The lopping off of two cylinders was last proposed and executed in 2005 and it turned out to be a totally different engine according to the experts at that time. And those were both port injected NA engines that were on very similar rev levels and internal pressures. This time there would probably not be a single part to carry over. Not even the spark plugs.Way to contradict yourself in one page.WhiteBlue wrote:andrew, you conveniently ignore the development time of the last "new" engine. The regulation was decided in December 2004 against firce opposition of BMW. The engine ran for the first time on track in December 2005 after just 12 months. The first race was on March 12th 2006 in Bahrain when all engine competitors turned up with V8s.
I wont post what I think of you. It violates a few rules.WhiteBlue wrote:No contradiction there. The V10 to V8 transition was a completely new engine and it was done in 12 months. There should really be no problem to to do a new engine again in 30 months. I think you do not understand what we have been talking about.Scotracer wrote:WhiteBlue wrote:The lopping off of two cylinders was last proposed and executed in 2005 and it turned out to be a totally different engine according to the experts at that time. And those were both port injected NA engines that were on very similar rev levels and internal pressures. This time there would probably not be a single part to carry over. Not even the spark plugs.Way to contradict yourself in one page.WhiteBlue wrote:andrew, you conveniently ignore the development time of the last "new" engine. The regulation was decided in December 2004 against firce opposition of BMW. The engine ran for the first time on track in December 2005 after just 12 months. The first race was on March 12th 2006 in Bahrain when all engine competitors turned up with V8s.
My chap, are you making detrimental comments about my view on an issue that you had no time to study and develop your own reasoning? That is not impressive at all. If you are competent enough to stand up for a reasoned opinion how new technology influences the next formula engine design you should have done your learning in time to understand my points that show the hollowness of Marmorini's claim.andrew wrote:How'd you work that one out? Because I don't answer within 30 secinds? FYI (not that it is any of your business), I am currently catching up on some work and am flicking between my work and F1 Tech as a breather every so often.WhiteBlue wrote:Second you are unable to argue any of the points I made.
I wasn't looking for an argument but merely read a comment with wild claims being passed as fact and no source quoted. Always quote your sources when claiming facts. [-X
However, I apologise in advance of being extremely busy at work and having to catch up in my own time. I will endevour to advise a few client's that they will have to wait a few days for their reports etc. as WhiteBlue requested my reply.
Too sarcastic?
Patients is a virtue dear chap.
