And you know this how?swarren7 wrote:Looks like Lotus will not be running "the device" this weekend at SPA. I was really hoping to see it in action finally.
Huntresa wrote:And you know this how?swarren7 wrote:Looks like Lotus will not be running "the device" this weekend at SPA. I was really hoping to see it in action finally.
http://formula-one.speedtv.com/article/ ... ice-debut/Huntresa wrote:And you know this how?swarren7 wrote:Looks like Lotus will not be running "the device" this weekend at SPA. I was really hoping to see it in action finally.
Moveable aero device. Not permitted.gilgen wrote:This may have been suggested before, but how about this? The rear wing is set up to provide the required downforce, with air being blown through the small upper tube. In other words, situation normal.
Now, inside the engine cover is a spring loaded flap that is tensioned to move when a certain airpressure (governed by speed) is reached. This closes over the upper duct, alowing the wing to stall and produce less drag. The air is now diverted to the larger exit, operating at a lower pressure, and dumping the air into a low pressure area.
Simple and passive.
I agree.PhillipM wrote:They really ought to just run it now or forget it, they're wasting far too much time worrying about testing and setting it up that probably could have been better spent elsewhere after all this will-they-won't-they debacle.
Depends if water getting into the nose scoop will adversely affect the airflow and stop the fluidic switch from working.Lycoming wrote:one race distance is a lot of testing miles...
I was thinking the same thing, and with races passing by without using it (and possibly losing points not benefitting of the possible advantage it gives them), it would become a useless investment for the last races, or it might be too late to use it as it will be banned for next year. But then again, someone said that the device might avoid the rules that ban DDRS.MarkedOne8 wrote:That only creates drag, but nothing positive.This would be Kimi's third race in a row runing that system and gaining no benefits.
Then they should abandon it now, if 3gp's don't have good enough conditions right through practice to race to even get some data back from it, then they'll never have a hope of setting it up in variable conditions on a race weekend, it'll only ever get used at one or two circuits, and they'll never be certain if they've set it right.myurr wrote: Depends if water getting into the nose scoop will adversely affect the airflow and stop the fluidic switch from working.
If the flap is inside the airbox, it would not be considered an aero device. Just as a fluidic device is not called an aero device.Timstr wrote:Moveable aero device. Not permitted.gilgen wrote:This may have been suggested before, but how about this? The rear wing is set up to provide the required downforce, with air being blown through the small upper tube. In other words, situation normal.
Simple and passive.
