McLaren MP4-29 Mercedes
beelsebob
beelsebob
85
Re: McLaren MP4-29 Mercedes
Xero wrote:The overheating shouldn't affect the running of the car. From what I make of it they're more worried about the integrity of several components beyond the heat exits, and potential failures because of it. I could be reading it wrong though. :roll:
It could well be that the suspension itself is getting too hot – hence only attempting to run the carbon, instead of the bodged together (reinforced?) suspension on one day so far.
Xero
32
beelsebob wrote:It could well be that the suspension itself is getting too hot – hence only attempting to run the carbon, instead of the bodged together (reinforced?) suspension on one day so far.
Yeah, that sounds spot on. I'm thinking back to the torched heat sensors on the rear crash structure last test too. Might be their butterfly suspension is concentrating the heat to different spots across the rear. Apparently they were running heat sensors today at the entrance of the rear brake ducts too, maybe worried about how much of that is being fed through the brakes?
Avocado
Avocado
Pup
Pup
50
I'm going to place my bet on the tires - given that McLaren's long runs seem to fade more than Merc's. The semi-stagnant pocket of air around the suspension could potentially cause trouble keeping the tires in the right range.
mclaren_mircea
mclaren_mircea
What do you want to say when you say that Mclaren's long run seems to fade more than Mercedes.
Pup
Pup
50
Look at the graphs of the stints that Blanchimont posted in the testing thread. Magnussen's times seem to drop off at a steeper rate than the others. Small sample size, of course, but we take what we get.
willmesquita
Pup wrote:Look at the graphs of the stints that Blanchimont posted in the testing thread. Magnussen's times seem to drop off at a steeper rate than the others. Small sample size, of course, but we take what we get.
Yes, seems we have a very intense tyre usage. :(
To do something well is so worthwhile that to die trying to do it better cannot be foolhardy. It would be a waste of life to do nothing with one's ability, for I feel that life is measured in achievement, not in years alone. ― Bruce McLaren
papayaorange.com.br
Richard
Richard
Please remember the car thread is meant for discussion of the actual features of this car. The long standing mantra is "If it is not on the car, then it's not in the thread".
Posts about the car being in the garage or the competence of RB management belong in the respective test or team threads.
Winter Testing 2014 - Session 3, Day 1 - Bahrain (27.02.2014)
Owen.C93
Owen.C93
177
Broken monkey seat.
OO7
OO7
171
Owen.C93 wrote:Broken monkey seat.
Must have been a very heavy monkey.
f1rules
f1rules
623
any aero people that can elaborate on this flow pattern
f1rules
f1rules
623
and this
CBeck113
CBeck113
51
f1rules wrote:any aero people that can elaborate on this flow pattern
Looks good, actually. The lower element of the wing is pretty even and symetric, so it has good,steady flow. The top element has the line across it because DRS was activated; that is where the highest flow will be found, since the element is concave and that marks the lowest point when open. The areas at the top of the element are washover from the other side of the wing, common and difficult to avoid without changing the profile of the wing - which is not allowed in this case.
