Harsha wrote:My Friend asked me a question so i was asking it for the experts
Is It possible to run RB their Max Possible Downforce with the Current Down on Power Engine
As we know with out right power output the Drag makes them even slower, so is RB running their Full potential even in DF or not?
You always have to deal with a compromise between drag penalty and straightline speed and this balance is optimised for laptime. Keep in mind that this is highly dependent on the track as well, which is why you see tracks such as Monza with minimal drag configuration and others such as Monaco with maximum downforce configuration. Having said that, you most certainly haven't seen the "max possible downforce" on the RB10 yet.
I assume what you are actually asking is whether RedBull have intentionally compromised their aero in order to compensate for a lack of power output. Without knowing the answer to that, I have seen no evidence for that. In fact, seeing both RedBulls on a regular basis low on the speed traps would rather indicate that they have not compromised their aero package. Additionally, removing drag to compensate for a lack of power output isn't as straightforward and trivial as one might imagine. Significant efforts to remove drag would have an inevitable impact on the balance of the car and could even affect the underlying philosophy that the car. I personally have a very hard time imagining that Adrian Newey would invest resources into such a workaround rather than to insist to solve the actual root of the problem.
