I have a pretty good idea of the numbers but I'm curious to see the numbers that gruntguru usedPlatinumZealot wrote: ↑11 Nov 2017, 02:14We can work it backwards knowing the boost pressure and air fuel ratio and fuel flow to find the volumetric air flow rate then divide by the plenum cross sectional area to get the air speed.
I would guess gruntguru used:MrPotatoHead wrote: ↑11 Nov 2017, 03:19I have a pretty good idea of the numbers but I'm curious to see the numbers that gruntguru usedPlatinumZealot wrote: ↑11 Nov 2017, 02:14We can work it backwards knowing the boost pressure and air fuel ratio and fuel flow to find the volumetric air flow rate then divide by the plenum cross sectional area to get the air speed.
Doesn’t necessarely have to be the case. It sounds very complicated to built in secret performance which can be accessed via customer software and interface, without the customer knowing it is there.Zynerji wrote: ↑09 Nov 2017, 03:04This is by far the most interesting question... hidden switch combinations? Should the FIA 2021 rules include all software and disclosure of modes to the customer teams as well?thedutchguy wrote: ↑08 Nov 2017, 21:47Interesting story by Matthew Carter (former team Lotus F1 CEO) on Missed Apex Podcast about Spa 2015, when Mercedes "gave Lotus a different engine mode" in order to have Grosjean finish ahead of Vettel. According the Carter, Grosjean told him after the race that the car had nevert felt like that (good) before. Lotus were neven 'given' that engine mode again.
You can watch the whole clip here: https://youtu.be/xBQA9eABkpc?t=27m10s
What I wonder is how Mercedes can 'give' or unlock an engine mode for the driver to use, when pit-to-car telemetry is forbidden? I understand how Mercedes can keep certain engine modes from their customer teams, but I'm a bit puzzled as to how they can choose to unlock them for a driver to use during a race when the car is on track.
This seems to be a crazy advantage to overcome. And provably why Ron Dennis dropped Mercedes in favor of the factory Honda deal.
Do pressure waves from valves closing affect mean flow velocity?MrPotatoHead wrote: ↑12 Nov 2017, 19:54Every intake that I design and run through CFD I do both a static flow simulation through all of the runners open and then a dynamic simulation with a true time based simulation of per cylinder intake valve opening time.
It’s amazing the differences in flow that you will see between the two.
What do u mean by"static flow simulation"? U mean steady state flow...MrPotatoHead wrote: ↑12 Nov 2017, 19:54Every intake that I design and run through CFD I do both a static flow simulation through all of the runners open and then a dynamic simulation with a true time based simulation of per cylinder intake valve opening time.
U mentioned that wanna to know a/f ratio to know volumetric flow, here u know that there is direct fuel injection , do u know when fuel is injected? In intake phase or compression phase?PlatinumZealot wrote: ↑11 Nov 2017, 02:14We can work it backwards knowing the boost pressure and air fuel ratio and fuel flow to find the volumetric air flow rate then divide by the plenum cross sectional area to get the air speed.
Static flow as in no interruption, people forget combustion events aren't continuous, the valves close and open and this interrupts flow, this is dynamic.amho wrote: ↑12 Nov 2017, 23:21What do u mean by"static flow simulation"? U mean steady state flow...MrPotatoHead wrote: ↑12 Nov 2017, 19:54Every intake that I design and run through CFD I do both a static flow simulation through all of the runners open and then a dynamic simulation with a true time based simulation of per cylinder intake valve opening time.
Fuel is injected in both, the turbulence during intake phase promotes mixing, as does EGR left over from the previous combustion cycle(by helping fuel vaporize). The ideal timing is in between intake and compression.amho wrote: ↑12 Nov 2017, 23:35U mentioned that wanna to know a/f ratio to know volumetric flow, here u know that there is direct fuel injection , do u know when fuel is injected? In intake phase or compression phase?PlatinumZealot wrote: ↑11 Nov 2017, 02:14We can work it backwards knowing the boost pressure and air fuel ratio and fuel flow to find the volumetric air flow rate then divide by the plenum cross sectional area to get the air speed.
They do for sure but the effect is less on an engine as the plenum pressure gets higher and the air more dense.godlameroso wrote: ↑12 Nov 2017, 23:19Do pressure waves from valves closing affect mean flow velocity?MrPotatoHead wrote: ↑12 Nov 2017, 19:54Every intake that I design and run through CFD I do both a static flow simulation through all of the runners open and then a dynamic simulation with a true time based simulation of per cylinder intake valve opening time.
