747heavy wrote:Thanks WB
AFAIK you will get best power at the stoichiometric ratio, leaner then this should not lead to more power - IMHO.
I do understand, that this is/was not attainable with port injection, therefor a slightly richer mixture is needed.
Is it fair to say, that stoichiometric will be the leanest possible mixture for max. power, so the most efficient setting for max. power? Therefor the full saving potential is limited at one point (for max. power).
I was under the impression, that the fuel saving potential of a GDI engine is higher at part load / throttle? Is that correct in your opinion?
Whould we/you expect to see other limits, like max. rpm and/or a max boost limit for the 2013 engines?
At lower revs (1000-4000) you can stratify and use highly over stoichiometric mix. On full song of approximately 10,000 or 11,000 rpm the injection speed is just good enough for one injection event which will give you slightly over stoichiometric mix. I would have to look in a book again to tell specific numbers.
Obviously the saving potential is greatest at low revs like 3000. That rev level would be usable with turbo engines but not very likely in an F1 power profile. This is why stratifying is unlikely in F1.
The efficiency over revs is also influenced by the speed of the injectors. They can give you 0.2 milliseconds injection time but not much faster with current technology. This translates to the rev limit of appr. 8,000 at for a regular injection window. Going higher with revs forces you to inject earlier in the compression stroke than optimal. It means you have to go richer than optimum because your spray cone has hit the piston and you need a richer mixture to reach ignition at the spark plug. The expert proposal puts the new engines at 11,000 rpm. I reckon that you would still be leaner than with port injection between 8,000 and 11,000 rpm.
Legal boost limit is planned at 3 bar according to reports.
