This nose cone is very bulky...Maybe they are planning to stick a motor in there to make it 4WD in the future?
From the video they put up the chassis itself is traditionally shaped, but there's a thin non-structural panel which makes the front bodywork trapezoid shaped, wider at the top than the bottom. So I don't think there is any more space for a front motor than now.dmjunqueira wrote: ↑30 Jan 2018, 17:19This nose cone is very bulky...Maybe they are planning to stick a motor in there to make it 4WD in the future?
My recollection was that the CDG didn't do what it promised to do. I think this split wing is more about dealing with the rear wheel wakes in lieu of the rear pods. They've not given any aero numbers, but I reckon this car will have a bit more downforce than the current model, which is ~1/4 to 1/3 of an F1 car, but with much higher efficiency because of the covered wheels. More downforce may be bad for racing, but higher efficiency will be better, so it should at least balance.bill shoe wrote: ↑30 Jan 2018, 17:31Several years ago FIA president Max Mosley was a fan of a concept where the rear wing was split into two halves and moved outboard behind the rear wheels. This meant air going over the center of the car would not be disturbed by the rear wing. CFD showed this made the airflow much better for a following car. Sounds perfect for the close racing in Formula E.
Looks are friggin irrelevant in a racing series.FW17 wrote: ↑30 Jan 2018, 16:25OMG the rear is so UGLY
http://a1.espncdn.com/combiner/i?img=%2 ... quality=40
Well, at least it's something. But I think a wing-car, closed-wheel formula would be even better.bill shoe wrote: ↑30 Jan 2018, 17:31There may be some method to the madness (madness = unconventional rear end and rear winglet placement).
You forget one important thing - Formula E is a spec series. The fact that there may be some form over function doesn't matter because everyone gets the same performance from the bodywork.
And this:mzso wrote: ↑30 Jan 2018, 18:57Something like a combination of these:
http://www.moteurnature.com/zvisu/2012/ ... V-P002.jpg https://i.pinimg.com/originals/d6/5b/13 ... 4a36b9.jpg
Meaning?enry86 wrote: ↑30 Jan 2018, 23:08And this:mzso wrote: ↑30 Jan 2018, 18:57Something like a combination of these:
http://www.aviastar.org/pictures/usa/no ... f-23_1.jpg
FIA policy is to revert upended cars. Then extract the driver. There was a press conference about the halo a while back, wherein FIA officials expressed this.chapmanlung wrote: ↑31 Jan 2018, 01:17...I do have a concern about the cockpit exit. For a driver getting out (regardless of the situation) they first have to climb out through the halo and then climb into the car. there seems to be a reasonable bit of bodywork in between the cockpit and the driver touching the ground.
In a stationary state, it would be easy for the driver to get in and out. but in an emergency like a crash, would it be dangerous for drivers to get out without the risk of stumbling?
Hmmm, aside from the stupid looking halo, I dont mind it. I might even start watching FE now.
Ugh. More superficial crap is one thing I don't miss in formula E (and 1).
