The engine will likely be a twin turbocharged 1.6L 4 cylinder with Kers. The turbo boost is expected to be around 3 bar in order to reach a BHP of 500 to 550. RPM's will be limited to approximately 10,000 to 11,000. The Kers output is expected to be 112kw (150 HP) and the battery storage is expected to increase to 2200 kJ. Quite frankly, I find those storage capacities to be a bit hard to believe. I doubt that the current batteries have that kind of capacity. If true, Kers would supply 150BHP for 24 seconds. If so, the car would have a maximum combined power of around 650 to 700 BHP.
Regarding the battery storage capacity, I think the more likely option would be to allow unlimited recharges and usages rather than the current limits based on total power available per lap. Storage capacity could be much lower if there were no per lap limitations on usage, and current battery design and capacity would probably suffice.
The one thing of note that I have seen regarding the chassis is the possible return to ground effects. Many people fear that this may signal a return to the type of cars that were banned in the '80s. Those cars had zero-travel suspensions, ground hugging skirts, and a very unpredictable and dangerous nature. That's not what I expect in the new generation of F1 car.
Instead, I expect to see a conventional looking car with a curved bottom. It will produce a venturi effect and provide about 60% of the total downforce. I would expect to see the wing size reduced and the shapes simplified. I suspect it will be a lot like the DP-01 that was used by Champ Car in 2007. The car will be safe and predictable.
http://www.formula1journal.com/2010/09/ ... lood1.html
