the surface material around the exhaust outlet look like bare CF to me. Is it strong enough to withstand the heat?
http://i.imgur.com/68l2m6E.jpg
I am a Ferrai fan and have been for almost half a century. But if you intend to bet against Newey I suggest you looking into a second job -- you'll need the moneyJuzh wrote:Exactly my thoughts. I bet you any money RB9 will be slower in melbourne than RB8 was in usa/brazil.Just_a_fan wrote:I get the feeling that the RedBull might be running out of development potential with this series of car (RB6-9) compared to others - albeit because they started ahead and the others have been catching up a lot of the time. Will be interesting to watch.
But it's not like he never was outdesigned.donskar wrote:I am a Ferrai fan and have been for almost half a century. But if you intend to bet against Newey I suggest you looking into a second job -- you'll need the money
The other teams are packaging a full size KERS which must account for some of the difference.SiLo wrote:So much open floor space compared to other cars, would love to see an internal packaging comparison!
If the tunnel/second floor wasn't there what would the difference in drag be? Less drag surely? (I'm not an aerodynamicist and I'm not trying to be obtuse just trying to understand the difference in concepts)Nando wrote:Does the tunnel really create that much drag though? Maybe it´s so optimized that it sucks in air instead of just taking in air?
Airflow connection has nothing to do with it ...the EDGE wrote:KATO wrote:It reconnects the air flow at the step to make the loss of air pressure minimal. Now I'm no an Aeronautic Engineer or an Aerodynamics expert. so my simple and I'm not even gona try to sound technical never do I like posting nonsense in Forums. Anyways my guess isMestrades wrote:
What is the function of this hole?
I think that the exhausts are a bit further away than in previous versions. Perhaps it's only an imagination...
BOTH Sauber and RedBull have placed relatively smaller 'vanity panels' on their stepped noses so they both have less weight by comparison to McLaren and Ferrari. Both have the the solution that takes air from Under the car and reconnects the loss of pressure at the Step so effectively with the cover and Sauber solution, it simply makes sense to me that less weight and that hole at the bottom of the nose should equal at the very least just as smooth an Air flow as the Ferrari and McLaren. If not maybe some small added downforce..... Now who doesn't welcome a tiny bit more downforce ..
surely the low CofG of pull-rood is of more benefit then saving a tiny amount of weight and having a tiny (if any) amount of extra downforce (personally i'd say it reduced lift rather then produced down-force)
Let's face it, it's been very rare and on the occasions when his cars have been outpaced it's generally because he hasn't ultimately been in charge and has been held back.timbo wrote:But it's not like he never was outdesigned.
