ringo wrote:That article isn't saying anything substantial.
It's telling me riding around on 3 wheels is advantageous and that in itself is.. I don't know what to say.
I can't get anything from this. It's not teaching us anything about the suspension.
I know what you mean, but .......
just over 50 years ago, Lotus were winning hundreds of open-wheeler races
the same was said then about (their) apparent 3 wheel cornering
at least it helps the powered end of the car
F1 front suspension geometry is disadvantaged by the aero driven structural configuration
anyway is required to give a large 'jacking' effect in corners to reduce compression of the suspension on the outside of the corner
so that the suspension will allow what us oldies regard as 'kerb hopping' (done when running relatively straight)
this geometry forces less than ideal camber gain
they attempt to alleviate this problem by using a rather large (currently notorious) static negative camber
since active ride was banned 'dampers' have developed to allow some of the characteristics previously considered unique to AR
ie dynamic stiffness very strongly variable with velocity etc, 'programmed' at buildup and by setup
'self-pumping' for ride height correction
and these sort of effects combined
surely passive devices can also adjust gas spring volume etc ?
