you are right, I assumed that you could shift the curves, as power is rpm independent. But the new version is stretched by 18000/15000 instead.Blanchimont wrote:Thanks again, rscsr. But could it be that you just shifted the curve to the right by ~3500rpm instead of multiplying the rpms by ~11500/8000=1,4375?
But the result is basically the same however you look at it. The new engine has about 46% of the power band which is usable, while the old engine only had 20% of it usable. (if you assume that performance over 600bhp is usable)
