Now I think that the load on the wheel is determined by the force with which the tire presses on the road. Changing the load at a given time: (Kt+Ct*D)*(Xu-Xr). And we must find the maximum value of this expression.DaveW wrote: ↑05 Mar 2018, 16:31I believe you have forgotten the inertia force acting on the wheel. If I simply rewrite your equation:Rustem 1988 wrote: ↑05 Mar 2018, 13:20...the load on the wheel W=Wst+ks(Xs-Xu)+Cs*(dXs/dt-dXu/dt)+kt(Xu-Xr)+Ct*(dXu/dt-dXr/dt)
Load on the wheel = Wst+(Ks+ Cs*D)*(Xs-Xu) + (Kt+Ct*D)*(Xu-Xr), where D is the operator d/dt.
Then dyamically, Mu*D*D(Xu) = (Ks+Cs*D)*(Xs-Xu) + (Kt+Ct*D)*(Xu-Xr). Here D*D(Xu) is the acceleration of the wheel, and Mu is the wheel (unsprung) mass. Wst disappears because it is balanced by static offsets of the springs. A similar equation can be written for the acceleration of the sprung mass, and the two can be solved together to compute the various responses of the vehicle per unit road input.
It is a little more than that, because the sprung mass connects the front & rear suspensions (so the sprung mass has "heave" & "pitch" inertias).
I hope this helps...
