Mercedes W13 Speculation Thread
F1Krof
95
Re: Mercedes W13 Speculation Thread
DiogoBrand wrote:
20 Jan 2022, 01:23
F1Krof wrote:
19 Jan 2022, 23:14
Are they allowed to run a cape under the nose as they were doing until now?
Also I wonder. Will it still have a purpose? Was it not designed to work with the Y250 vortex?
Won't they be useful directing as much air as possible to the Venturi tunnel intakes where the sidepod extravaganza used to be?
Wroom wroom
SiLo
139
F1Krof wrote:
20 Jan 2022, 13:58
DiogoBrand wrote:
20 Jan 2022, 01:23
F1Krof wrote:
19 Jan 2022, 23:14
I'm sure I saw something about the capes being banned? Might fall into the area where the barge boards are?
Felipe Baby!
Stu
SiLo wrote:
20 Jan 2022, 15:30
F1Krof wrote:
20 Jan 2022, 13:58
DiogoBrand wrote:
20 Jan 2022, 01:23
Not banned per-se but technically so due to the minimum radius rules for bodywork. The ‘tea tray’ area has also been affected by this.
SiLo
139
Stu wrote:
20 Jan 2022, 18:18
SiLo wrote:
20 Jan 2022, 15:30
F1Krof wrote:
20 Jan 2022, 13:58
That's the one, thanks Stu.
Felipe Baby!
Henri
Henri
-6
Who is the chief aero guy at merc since allison and aldo costa have left ?.. is lorenzo sassi still part of the engine team ?
Holm86
249
Henri wrote:
21 Jan 2022, 08:35
Mike Elliott
AeroDynamic
349
Not sure if this is the right thread for this, but, can someone tell me what potential degree of benefit the squatting-no-rake engineering Mercedes deployed last year, May hold for the new ‘22 cars?
I understand the effect it had on the old cars but would this work the same, worse, or better, in theory, with these new ground effect cars? Like, would these new ‘22 cars push all times to adopt high rake with shorter wheel bases, or would it push more teams to adopt for long wheel base and low rake? Or is it unchanged and both philosophies could prove equally competitive?
I know it’s just speculation probably but I’d really value some opinions on this, especially from the most tech savvy users, thanks!
I think we will still see teams trying to run a high rake to get more expansion from the venturi tunnel, but they will have a greater challenge in "sealing" the sides due to the higher air flow expected under the floor. Those cars will still have more drag though. Mercedes might still yet go with low rake if the numbers show that philosphy is still viable.
SiLo
139
PlatinumZealot wrote:
24 Jan 2022, 14:53
Plus they won't have the huge amount of vortex creating and management surfaces in the barge board and floor area either. I think high rake will be a real challenge, but there will still be some degree of rake (pun intended).
Felipe Baby!
Giando
93
Do you remember when back in 2017 (or 2018?) Mercedes brought a (relatively simple) bodywork version for the first test session and then came up with a completely new one for the last test before the start of the season?
Would it be possible this year to see Merc (or other teams) do something like that or it would be complete nonsense given the small amount of time allowed for testing?
SiLo
139
Giando wrote:
24 Jan 2022, 15:03
I think considering how big the changes are, the teams will want as much track time as possible to help understand the car and correlate wind tunnel data. With the reduction in wind tunnel time, having good correlation becomes so much more important.
Felipe Baby!
Holm86
249
Giando wrote:
24 Jan 2022, 15:03
I don't think that feasible with the budget cap
De Jokke
24 Jan 2022, 14:53
I thought low rake was the way to go for 2022?
Mercedes AMG + Hamilton => dreamteam!
If you can't beat'em, call Masi!
LM10
LM10
122
De Jokke wrote:
24 Jan 2022, 15:37
24 Jan 2022, 14:53
Thinking of the venturi effect it seems to be the best to have the underbody as near to the track as possible. That’s also what Newey told. Don’t know how high rake is playing into that.
Big Tea
99
De Jokke wrote:
24 Jan 2022, 15:37
24 Jan 2022, 14:53
As a higher rake (in effect) alters the 'pressure' along the underfloor, does the rake angle 'move' the C.O.G with speed?
(Edit, is it still C.O.G with downforce?)
