True, true.Fil wrote:Just remember what state BMW was in this time last year. That may ease your worries a little..
Perhaps it doesn't dry at all. Being parafin based, its probably not even paint. It's a coating that spreads out on the car surfaces, highlighting areas of flow impingement and near-surface flow fields. Over the course of a few laps, the combination of many cycles of left and right turns, rapid accelerations and decelerations and umpteen other variables will cause the parafin to spread out to wherever it's going to spread out. Someone may look at the car after and see that there is a particularly high amount piling up in a certain spot. A spot that shares the EXACT same stagnation pressure value as many other spots from CFD and wind tunnel testing.kilcoo316 wrote:At what point in the lap does it 'dry'?McLaren's explanation:
"This is what we call a 'flow vis' (visualisation) - where we take a paraffin-based light solution and apply it to the car."
"The solution is light enough to flow over the car, drying quickly to determine the airflow over the bodywork."
What are the ambient conditions at the time it 'dries'?
Note - use of the word dry in inverted commas - as the viscosity will be changing right up to the point of 'drying' (i.e. eventually so viscous it ain't going nowhere anymore).
There are just so many variables to this testing 'method' that it reeks of desperation or a flat out decoy.
*snigger*McLaren explained this is a routine operation. "This is a common occurrence when testing new cars and is used to confirm the wind tunnel readouts."
A common occurence when something is FUBAR.
What do they determine from that - there is indeed a front wing wake at approximately 5 degrees (give or take 2 degrees - or something similarly ludicrious!).
Without having exact control over the boundary conditions, the explanation given is bull. You'll verify f**k all in the way of wind tunnel tests from some paint streaks on a surface that changes direction all the time.
For instance - what happens when the car is going laterally at 3g? Is the paint not expected to move towards the outside of the car?
No, I'm not saying both are FUBAR.slimjim8201 wrote:Who are you to say that it is worthless and their CFD/wind tunnel programs are FUBAR?
I'm not sure if this is pressure paint though. I think it is applied uniformly over the body and then changes colour dependant on airflow incidence through oxygenation.slimjim8201 wrote:A spot that shares the EXACT same stagnation pressure value as many other spots from CFD and wind tunnel testing.
I think you are coming at this from the assumption that their CFD wind tunnel tests aren't good/valid. I don't think they are using this method of flow visualization for anything other than to have another method of flow visualization. There are no big secrets here, they aren't trying to throw off other teams or lead them to believe that they are up a creek with their non-track testing.kilcoo316 wrote:No, I'm not saying both are FUBAR.slimjim8201 wrote:Who are you to say that it is worthless and their CFD/wind tunnel programs are FUBAR?
As you well know, you cannot exactly extract hard numbers from this kind of stuff (paint).
Now, all that means is you can perform qualitative comparisons (I assume you are well aware of qualitative and quantitative comparisons yes?).
You know about CFD - for example if your model is predicting a separation bubble at 15% cord length with reattachment at 40% chord length, while experiments say 10% and 30% - you can live with that, its not great, but at least your physics are right. [That is a (very) rudimentary quantitative comparison]
Now, if your model is not predicting separation at all... while these paint tests predict there is separation, you'd be a very worried man, and rightfully so [qualitative comparison - the physics between prediction and reality has changed].
I'm saying that if they have wind tunnel/CFD problems, and these crude (and they are crude) tests show qualitative differences - they are deep deep deep in the brown stuff.
But if you are a mclaren fan - I would be worried - does the presence of the paint tests indicate the suspension deflections at speed (aero load) are very far from what the wind-tunnel said the aero load would be?
Maybe they are grand and all this is mclaren throwing a few people off the trail, but if they are truly worried enough to try and check their wind tunnel accuracy with this...
kilcoo316 wrote:I'm not sure if this is pressure paint though. I think it is applied uniformly over the body and then changes colour dependant on airflow incidence through oxygenation.slimjim8201 wrote:A spot that shares the EXACT same stagnation pressure value as many other spots from CFD and wind tunnel testing.
Agreed that pressure paint is very useful - but I *think* they have to be used in a controlled environment with detailed light sensors to be of use.
Even then - there can be large errors within those tightly controlled environments (i.e. clean wind-tunnels with zero outside influences) - imagine what they would snowball to on a track!
Would everyone agree that the car would actually look decent, and perhaps even good if they got rid of the undernose bulge and diffuser-like vanes? Amazing how one area can make the entire car look bad.Shaddock wrote:Torpedoes away !!!
Not to mention the fat bodywork around the rear end!slimjim8201 wrote: Would everyone agree that the car would actually look decent, and perhaps even good if they got rid of the undernose bulge and diffuser-like vanes? Amazing how one area can make the entire car look bad.
Or they might be anticipating an extension of the diffuser producing more downforce and so are testing with a simulated configuration to see what difference it makes. Do we know for sure that they are only running the 08 wing today or have they been switching between the two. Was their best recorded time set with the 08 or 09 wing? If we don't know that how can anyone jump to the conclusion that they're up a certain creek?spaman wrote:They might want to check the differences to better understand what is caused by the '09 wing and what is caused by other changes.djos wrote:Yep, the Macca has its '08 wing on again:
http://74.125.19.113/translate_c?hl=en& ... 4picOtx9xw
I can't understand why they would do this in good weather? last time their excuse was because of the bad weather.
What we do in law stuff sometimes, is to compare the regulations in different countries to better understand the differences. It might be just the same in terms of technical / aerodynamical developement and understanding.
