Ferrari F2012
Kiril Varbanov
147
Re: Ferrari F2012
@shelly - I'll leave it to the pros, then :)
Hush
Hush
Re: Ferrari F2012
Diesel wrote:So there's a rumor of a Fry/Byrne(Burn) floor that heats up/gets hot... this has got to be a joke...
Indeed, and people are entertaining this notion.
The regulations are pretty tight concerning the floor. A flat bottom as a matter of fact... There is only so much you can do with it.
amouzouris
105
Re: Ferrari F2012
go at 0:30...is it just me or did the driver(i cant tell who it is) have to lift off in the middle of the corner as the car tried to slide?
edit: that said, i think the car looked faster than the others..
[youtube]http://www.youtube.com/watch?feature=pl ... KF7xZIk4Do#![/youtube]
Hail22
144
Re: Ferrari F2012
Rory Byrne may have designed a very old concept...it was a double floor, however the lower section was curved and hollow which with air going under the car went into this void and pushed the vehicle lower but once again its pure speculation...
Gilles Villeneuve
Moanlower
Re: Ferrari F2012
Has this W-duct concept been discussed here? I wonder if it's legal and if this version would cause instability in corners since the load on the wing could suddenly shift.
[youtube]http://www.youtube.com/watch?v=GJ9cFis55xM[/youtube]
Edit: should've posted this in aero sector instead of F2012 topic. Maybe someone with more aero knowledge could start a topic on this?
Losers focus on winners, winners focus on winning.
blokkie
blokkie
Re: Ferrari F2012
yes it has been discussed already .. a lot ..
i70q7m7ghw
i70q7m7ghw
49
Re: Ferrari F2012
Let's hope it doesn't get too hot or someone might get Byrned... heck you chould even Fry some eggs on it... :lol:
I can only imagine this rumor has come from some poor literal translation of those two names.
markc
Re: Ferrari F2012
you massa be joking, that's no way to be going alongso
... too much? ...?
shelly
shelly
136
Re: Ferrari F2012
Kiril Varbanov wrote:@shelly - I'll leave it to the pros, then :)
Leaving it to the pros takes away most of the fun of disussing, without taking it too seriously.
twitter: @armchair_aero
joempower
joempower
Re: Ferrari F2012
amouzouris wrote:go at 0:30...is it just me or did the driver(i cant tell who it is) have to lift off in the middle of the corner as the car tried to slide?
[youtube]http://www.youtube.com/watch?feature=pl ... #![youtube]
Very strange he's lifting mid corner possibly to correct under steer.
Reason: Removed video quoted from post above
F1.Ru
21
Re: Ferrari F2012
wesley123 wrote: Okay so you know that exhaust gasses are 800 degrees and the floor will max. be 100 degrees. See where I am going? A heated floor will do nothing at all other than become hot. First of all the heated floor only will heat the air a minimal amount, it does not blow anything uless the EBD, blowing 800+ degrees exhaust gasses in this area.
The gain achieved by a 'hot floor' will be 0.0 and only over complicate things
But a heated floor certainly will help to change the direction of the exhaust plum and thus make it more hot and the combined effect of this two can change the scenario a lot.
how can u say this as i know that every little things can effect the direction and performance of the car, while what we already seen from Scrabs articles that Ferrari is probably trying to channel their exhaust Gas toward the diffuser edge through using air from and over the side of the sidepod. So this can also help to generate necessary pressure difference that can bring more and higher velocity air toward the rear end.
May be i am wrong in details analysis but that does not mean that a heated floor can not help anyhow........... :D
Formula One is a game.............. but not any ordinary game for me
Re: Ferrari F2012
At the speed of the airflow over a floor the heating effect would be negligable, you'd probably be lucky to see 1*c rise at the airstream closest to the surface.
bonjon1979
bonjon1979
30
Re: Ferrari F2012
PhillipM wrote:At the speed of the airflow over a floor the heating effect would be negligable, you'd probably be lucky to see 1*c rise at the airstream closest to the surface.
This - compare with the 800*c you get from an exhaust and you can see that this would have v little effect
Gridlock
30
Re: Ferrari F2012
Yes, if you're using a 'heated floor' to try and gain direct aero benefit.
But this hypothetical wonder floor could just be for cooling. I seem to recall the original rumours we about new cooling innovations, not EBD replacement.
#58
bonjon1979
bonjon1979
30
Re: Ferrari F2012
Gridlock wrote:Yes, if you're using a 'heated floor' to try and gain direct aero benefit.
I see - some kind of heat transfer taking it out of the radiators. It would explain why their inlets are so small.
