Red Bull RB9 Renault
Juzh
161
Re: Red Bull RB9 Renault
Any visible updates?
Kiril Varbanov
147
Rear wing - simplicity. Just look at the height.
Image credit: Obviously, Tobi from AMuS.
Similar versions used in Monza last year. The Spa version from 2012 was higher with three diagonal louvers.
Higher nose and a "Lotus" diffuser on the RB9
dxpetrov
dxpetrov
-7
Also, the nose is different. Much higher and pointy.
emmepi27
emmepi27
141
New diffuser, again! Testing by Vettel (Webber has run with different version)
Belgium 2013 - Friday (23.08.2013)
Huntresa
Huntresa
No pics of the new nose ? No more going downwards on the new nose, much more square like Merc nose.
emmepi27
emmepi27
141
The new diffuser is very similar to Mercedes one. Last version is much similar to Lotus
gary123
Image here it is ;)
FrukostScones
163
SectorOne
Different brake discs front and back, (note the holes)
VarioR
The nose seems a little bit diferent
http://www.planetf1.com/photo-gallery/8 ... pa#photo=1
Being a racing driver means you are racing with other people. And if you no longer go for a gap that exists, you are no longer a racing driver because we are competing, competing to win...
dxpetrov
dxpetrov
-7
Yes, apparently it has passed FIA crash test in order to homologate for the race. Extensive revamp up and down the chassis, probably the last push before the development stops. It just shows how much are they ready to invest in order to stay on top. :shock:
VarioR wrote:The nose seems a little bit diferent
Thanks for the link. For convience I copied the image url for easy view here:
Joie de vivre
there's barely any RW :shock:
