Very nice article by Scarbs as always. But what I didn't get was his proposed alternative nose which was short and rounded. Can somebody explain the concept?Kiril Varbanov wrote:Scarbs has extensive number of pages on 2014 aero and design intricacies at the latest Motorsport Monday issue - http://digital.motorsportmonday.com//la ... 1e05c8534a
are you talking about feeding that air through the starter hole? The inlets would be legal as far as i'm aware.Manoah2u wrote:is it possible according to the regulations to have a inlet at the front of the car that'll direct air through the tub towards the rear through canals? or possibly from an opening in the airbox steering air towards the floor at the back?
that photo is from this video http://www.youtube.com/watch?v=Lpu4QPplW3YtechF1LES wrote:https://twitter.com/ToroRossoSpy/status ... 2853427200
Apologies if this has been suggested earlier, I think it has been, just that then we hadn't seen...
...this incredibly static vortex:
Then there is this interpretation of where it is going:
Certainly the condensation trail goes all the way to the edge of the floor, so it is reasonable to think that the vortex itself extends well beyond the wider part of the sidepod.
This is an interpretation of what it might be doing there, rather than having its effect all the way down at the rear wheel:
In that case, the main effect of this vortex, for Red Bull an teams that get it this static only, would be to extract air from under the floor, "sealing" the floor sides. This would almost certainly work at the floor's edge, very likely at the (suspiciously round) sidepod bulge, and possibly well behind it. The exhaust is presumably still in charge of sealing the floor - rear wheel interaction area.
This might explain the ridiculously extreme rake of the RB9. Some of it from the blown exhausts, that other teams also had, some of it from this flap vortex making sure the air moves outwards (or at least it is pushed that way so some extent) all along the floor's side edge. It is a side skirt of sorts, with this effect alone allowing the middle of the floor to be quite high (a necessary side effect of having the very rear that absurdly high, with the exhaust blowing making that part possible).
Arguably it could be this effect that the other teams were missing, as a vortex that either moves or is shorter, like what the Ferrari showed, will die earlier, or move away from the floor, allowing air to rush in from the sides.
