[MVRC] Mantium Virtual Racecar Challenge 2016
Alonso Fan
Re: [MVRC] Mantium Virtual Racecar Challenge 2016
Alonso Fan wrote:
30 Mar 2017, 20:14
rjsa wrote:
30 Mar 2017, 20:04
Create a folder with your user name under this 'OpenFoam' cases dir.
Go to 'info->directory info' in the GUI menu and post what's in there.
http://i63.tinypic.com/126a41y.png
ok so I can load the input files into mvrc helper, but case is not creating and I think it has something to do with this whole openfoam folder issue
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
Alonso Fan
Aha! I have something.
I renamed the shared directory in the vm to 'c/Users' instead of 'c/users'. now openfoam recognises that there are files in the workingDir.
it's a start I guess. helper is creating a case but seems to be stuck on 'checking of files'
SHR Modding
Youtube
Twitter
Discord
rjsa
rjsa
51
What I have:
-Virtualbox:
Folder path: c:\openfoam
Folder Name: c/Users
-On Windows:
c:\openfoam\Ricardo
-GUI Shared folder:
c:\openfoam\Ricardo
My user name is 'Ricardo'
rjsa
rjsa
51
@flynfrog, I think I hit the report button by mistake.
Alonso Fan
rjsa wrote:
30 Mar 2017, 20:35
What I have:
-Virtualbox:
-On Windows:
c:\openfoam\Ricardo
-GUI Shared folder:
c:\openfoam\Ricardo
thanks for sharing your setup.
but I have the same issue as before, helper is stuck on 'checking of files'
how large is your vehicle_body.stl file?
SHR Modding
Youtube
Twitter
Discord
rjsa
rjsa
51
25mb, ascii.
I've actually gave up on the GUI and I am running all by hand for some time.
By hand I ran bodies up to 120mb until I found a proper meshing workflow.
Alonso Fan
rjsa wrote:
31 Mar 2017, 00:56
25mb, ascii.
Mine is around 50, so shouldn't be a problem. I think I'll run manually. Please can you explain to me the commands to create a case? And post processing?
Btw openfoam is working now that I added the capital 'U' in virtual box. So everyone having this issue, rename the shared folder path from 'c/users' to 'c/Users'.
SHR Modding
Youtube
Twitter
Discord
rjsa
rjsa
51
I have a batch that will jump into the case dir, run it, then jump back and do the mesh merging magic. Then post.
Most times it's just replacing the body stl between runs, easier done by hand after you catch the rhythm.
I'm at the airport into an international trip for a week :( so I don't have access to my folder structure or batch files.
Anyone there able to chip in?
From memory:
Creating the case is explained in the MVRC readme file. It generates the folder structure and the command to build the case.
This will generate a folder structure and the runcase.sh file that will run the case. You need to jump into the folder in the terminal window then run:
chmod +x runcase.sh
./runcase.sh
rjsa
rjsa
51
Post is done by the other two programs included in MVRC
Alonso Fan
rjsa wrote:
31 Mar 2017, 01:11
From memory:
chmod +x runcase.sh
./runcase.sh
Thanks for all your help!
Have a nice trip
I'll have a go at it as soon as I have fixed some overheating issues on my pc, hopefully by Sunday
SHR Modding
Youtube
Twitter
Discord
Alonso Fan
So I finally got the case created today using the cmd version of w flow.
I have also found the issue of why helper wasn't creating the case and it seems it was because the wheels were binary stl files. But helper didn't give any error so it was really confusing. As soon as I ran wflow from cmd it gave errors for all 4 wheels.
Perhaps there is no issue with helper after all other than the shared directory error. I will try again with the new wheels and try to create the case through helper. At the moment I'm on iteration 267 ish of my car from le mans, as an opening test case. PC is running very hot and on the brink of shutting down, running close to 80 deg centigrade with a desk fan blowing along the side of the case at full power. Hopefully I will fix my overheating issue tomorrow and run some other simulations
Btw how many iterations is the MVRC fast option?
SHR Modding
Youtube
Twitter
Discord
CAEdevice
50
I think 500 or 1000 iterations.
Wich is your hardware configuration?
Once I was in a similar situation and had to slow down the cpu (from 2400gHz to 2200gHz with 0.1 less cpu voltage).
rjsa
rjsa
51
1000 on fast, 1500 on regular
machin
162
Who's going to copy the big front wheel fairings?!
Alonso Fan
CAEdevice wrote:
31 Mar 2017, 20:57
the gui still wont generate a case for me, but even so, again a big thanks to hp racing for trying to cater for us cmd newbies. just a few niggles to sort out and it will be as bullet proof as merc :D
yes it ended up being 1000 I think I did it on fast
HW specs:
Asus M5A97 R2.0
AMD FX 6350
8GB RAM
Radeon R9 270X
nothing special
btw the case ran and i'm getting some odd results. not sure but it seems the engine intake and exhaust are running the opposite way
SHR Modding
Youtube
Twitter
Discord
