[MVRC] Mantium Virtual Racecar Challenge 2016
CAEdevice
49
Re: [MVRC] Mantium Virtual Racecar Challenge 2016
Interesting car (except the airscope).
About the hardware: the RAM is the biggest limit.
Alonso Fan
CAEdevice wrote:
31 Mar 2017, 22:22
Haha, the air inlet was hacked on last minute to comply with the rules. I didn't have enough time to do a proper job and, well it worked so it stayed. The car was basically all designed by visual inspection because last season I didn't have enough time to set up w flow and test etc.
Cooling was horrible, I'm looking to a different but familiar concept for this year, (and a better cad package)
It's the car I used for le mans last year. I thought it would be a good place to test if OF is working because I already have the correct official results
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
Alonso Fan
he does anyone know how to solve this error?
SHR Modding
Youtube
Twitter
Discord
Alonso Fan
Alonso Fan wrote:
31 Mar 2017, 23:31
http://i63.tinypic.com/11lncs2.png
its ok I found the error. the shared directory likes to be called 'openfoam' and nothing else
SHR Modding
Youtube
Twitter
Discord
variante
138
machin wrote:
31 Mar 2017, 21:21
Who's going to copy the big front wheel fairings?!
Yeah, I don't know what is up with those things... Possibly, they are trying to decrease the amount of airflow hitting the "bonnet" and the canopy, overcompensating the increase of drag of the wheel fairings.
BTW have you seen those rear view mirrors? :o
CAEdevice
49
Maybe it has something to do with the cooling inlets flow? I would need to see the car from above... maybe tomorrow in Monza :)
machin
162
Also interesting that both Toyota and Porsche have separated the front bodywork from the side pods so the radiator inlets are visible from above / front.
I wouldn't be surprised if those clear rear-view mirror fairings get banned: surely they add reflection and distortions?!
EDIT: I wonder if the bigger wheel fairings simply allow them to take a more idealised "tear-drop" shape whilst encompassing the front wheels?
CAEdevice
49
machin wrote:
01 Apr 2017, 12:20
I think so. I guess that large or ordinary wheels fairings hava a small impact on the drag.
LVDH
46
Maybe by increasing the size of the wheel fairings they reduce the section between them and the cockpit resulting into increased air speed at the front top diffuser exit. This increase in air speed leads to a lower pressure which might help extract air out of the front diffuser.
rjsa
rjsa
51
But wouldn't the effect on lift be more damaging?
My diffuser trailing edge isn't open on top, so I wouldn't know if it's net positive in that case.
LVDH
46
rjsa wrote:
02 Apr 2017, 15:15
Damaging yes, more is the question. Usually there is no free lunch. In the end you guys have similar cars and CFD. Maybe we will see a solution like this soon in MVRC.
CAEdevice
49
I have just come back from Monza, and I could see the Porsche LMP1 (on the track and in the box without the front cover ).
My impression is that they want to direct all the flow into the cooling inlets.
The Porsche also has interesting winglets under the front sospensions. I guess that they are more important than the visible parts of the car.
I also met people from Team Variante, but their car wasn't on the track yet.
CAEdevice
49
About the Toyota 2017: it looks that my 2016 layout (confirmed for 2017) was not completely crazy (also the Audi 2017 would have had similar features in front of the rear wheels arches).
Afaik the point of the fender shape is to kill lift. Push the air around the car instead of over it where it will generate lift.
I do think these fenders look bigger than they really are. Porsches fenders have been really smooth in the past, and these are much more blunt. That they then also use all area available for the headlights makes the whole thing look much bigger
variante
138
wesley123 wrote:
03 Apr 2017, 22:34
Nono, they actually have a much larger area than the minimum possible:
I'm still convinced that those things (whatever they are called) are designed to avoid a sort of "parachute effect".
