Ferrari SF23
codetower
Re: Ferrari SF23
Here's a better shot of the mirror, courtesy of F1ingenerale:
looks to be on Sainz' car only for comparison.
edit: wrong image posted
Re: Ferrari SF23
2022 mid/high downforce wing spec also with single pylon. The 2-pylon spec must be there for spare parts then.
The track did speed up a lot with new configuration, so it's possible maximum downforce is no longer needed. Front left tyre will suffer the most and the track is not rear limited in this new configuration at all. So, you don't need as much rear loading now, making it possible to cut some rear downforce and drag.
Also, as expected, no downwash sidepods. Nugnes strikes out again :lol: Front wing with the same load as Monaco, unsurprisingly.
gordonthegun
254
Re: Ferrari SF23
Do you think possible that they are configuring two cars with different setup and components?
Maybe one with the old RW/rear-suspensions/sidepods/floor/mirrors :mrgreen: and the other with the new ones for a more effective comparison.
Farnborough
Farnborough
94
Re: Ferrari SF23
gordonthegun wrote:
01 Jun 2023, 14:35
That would give excellent corellation/data analysis, along with the data set from last year (it was pretty rapid that weekend) to produce a lot of valid comparison for the team.
Benchmarked against RB performance data over two iteration as well. That would seem a cost effective exercise, given that they've a little more breathing space in the FP here vs Monaco too.
Re: Ferrari SF23
gordonthegun wrote:
01 Jun 2023, 14:35
For friday FP? Absolutely.
Venturiation
Venturiation
98
Re: Ferrari SF23
Vanja #66 wrote:
01 Jun 2023, 14:12
https://pbs.twimg.com/media/FxiPEAjXsAE ... ame=medium
https://www.racefans.net/wp-content/upl ... _HiRes.jpg
Redbull Sidepods are coming according to formu1a.uno and they are reliable
Re: Ferrari SF23
Venturiation wrote:
01 Jun 2023, 16:10
Autosport report the same
We'll probably have pictures of them before the end of the day
Venturiation
Venturiation
98
Re: Ferrari SF23
01 Jun 2023, 16:11
Venturiation wrote:
01 Jun 2023, 16:10
They will probably run 1 upgraded car and 1 old to compare
Re: Ferrari SF23
https://www.motorsport.com/f1/news/ferr ... /10476762/
The english version of Motorsport also corroborating.
The old version is still here.
Can't be sure if those are the new pods, but there's some different fins here.
ing.
59
Re: Ferrari SF23
Venturiation wrote:
01 Jun 2023, 16:13
If that’s the case, can’t be a huge change if the car can be reconfigured overnight.
Seems to me the sidepod cooling layout is similar so maybe just changes to the sidepod trailing edge and maybe undercut treatment.
Also, I understand doing A - B testing, but seems almost due to lack of confidence in their analytical tools than anything else. They seem to do this a lot and wastes an opportunity to get set-up learning across two cars. For comparison, Merc ran both cars in updated configuration last race with no back-to-back testing.
ing.
59
Re: Ferrari SF23
Sevach wrote:
01 Jun 2023, 16:22
https://cdn-6.motorsport.com/images/mgl ... ail-1.webp
https://cdn-4.motorsport.com/images/mgl ... ont-1.webp
https://cdn-6.motorsport.com/images/mgl ... ont-1.webp
https://cdn-3.motorsport.com/images/mgl ... ver-1.webp
Can't be sure if that's the new pods, but there's some different fins here.
Yes, louvres area seems convex. Possibly leading to cannon-shaped exit?
Manfer
Manfer
Re: Ferrari SF23
The fin right next to the roll hoop has some crazy geometry!
christian.falavena
Re: Ferrari SF23
I bet all that the waterslides are not disappearing, then most probably they will transform the shape more like AM/Mercedes. Impossible for FERRARI concept to get completely rid of it
Venturiation
Venturiation
98
Re: Ferrari SF23
ing. wrote:
01 Jun 2023, 16:32
Venturiation wrote:
01 Jun 2023, 16:13
They are saying redbull sidepods
New rear suspension and new floor
So almost a new car
Alonsismo
Alonsismo
Re: Ferrari SF23
