A fine example of vortex lift.gilgen wrote:THAT@S different.
ANY engine takes more to operate than it puts out. And there might be design problems, but not theoretical problems. Ask Otto.strad wrote:I believe that originally they figured it took more to operate than it put out...something along those lines..The original with it's poppet valve and low compression was very inefficient...I don't think peddaling a bike is the same.
Luckily the bumble bee does not know this and flies happily aroundgilgen wrote:......
Now a bunble bee, THAT@S different.
I have taken a detailed look at Luca Marmorini's claims in the engine thread. I believe that the Ferrari points will not stand up to scrutiny and McLaren have said that they do not support Ferrari's claims.gilgen wrote:I understand that Ferrari are not in agreement with the 1.6 turbo 4. They feel that the present 2.4 v8, can be reduced to 1.8 v6, at a far lower cost, and requiring less mods to the cars. This sounds quite sensible, but would then clash with FIA intention to use the same formula in WRC, WTCC and FIA GT.
wesley123 wrote:you can also easily convert the V8 into an 4 cylinder by cutting it in half, then you only need to increase its bore.
I like your inclusion of the Triumph engine. But not many will know that this was half of the V8 used in the Stag.marcush. wrote:Wesley ..no offenses there ..i was just having a laugh about it.. don´t worry about me .
To come back to it on a serious note,
If you cut the current engine in half you got only 1200cc ....so you need bigger bore so the whole idea of sving anything is already blown out of the window .period.
No question you can make a I4 quite easily from a V8 .But in all honesty that has no resemblance to F1 .Look up the ED pink I4 with Nascar Head... even them do the whole shebang completely new almost nil caryover there ...It´s just not feasible from wher F1 engines are currently.to cut off 2 cylinders would be a lot easier -geometrically it would be a 1.8l ´..but no matter how you do it its a completely new engine.
