2014 Design
bonjon1979
bonjon1979
30
Re: 2014 Design
Um, it looks, kind of alright. In fact I quite like it from the side as the downward sloping nose is much better than the high ones we've been used to. Of course, you can't really see the nose from this view point so maybe have to reserve our judgement!
Holm86
249
Re: 2014 Design
Sidepods looks to be quite undercut?
CBeck113
CBeck113
51
Re: 2014 Design
Holm86 wrote:Sidepods looks to be quite undercut?
Wanted to say the same, almost like the F138 without the exhaust. They do seem to flatten out at the end too, to create some downforce...I'll take a look at reworking the picture to get some more detail from it. If someone else is faster than I am... =D>
Holm86
249
Re: 2014 Design
Is the narrower front wing the biggest change?
“The front wing change is significant; it's a completely different concept for 2014. Visually it's one of the biggest changes. That was a big task, rebuilding all those aerodynamic structures from the front to the back to complement the smaller rear wing. The loss of the lower rear wing, or beam wing, leads to a significant loss of performance. That lower wing helped connect the diffuser to the top wing and gave those two areas a lot of support. Without it, it's become very difficult to extract performance and it's going to be quite a tricky area to keep stable. So there was quite a dramatic loss in headline downforce numbers, while there was also a drop in drag, which has fallen quite dramatically as well.”
Earlier I said that loosing the beam wing would not only effect the diffuser but also the rear wing. People didnt believe that but i guess Andrew Green confirms this.
Rest of the interview here
ebare
ebare
Re: 2014 Design
Don't want to be silly, but i think he just shows is better angle. The height in front of the cockpit is clearly the 625mm allowed, extended so much to the front that it must feature one modesty panel. Perhaps it's design isn't far from what Caterham had already show, at least judging for the small grey shadow bellow the blue letters. Like the new livery, the old chromatic scheme was getting "tired".
emmepi27
emmepi27
141
Re: 2014 Design
Are you sure about central pylon/pylons? And if they use the endplates directly fixed to the floor?
ebare
ebare
Re: 2014 Design
Special request: can someone please tell where to find F3000 lap times? Thanks.
CBeck113
CBeck113
51
Re: 2014 Design
emmepi27 wrote:Are you sure about central pylon/pylons? And if they use the endplates directly fixed to the floor?
https://pbs.twimg.com/media/Behk3RHCUAAtorx.jpg
I said it somewhere before, but I think that this situation could be used to flex the entire diffusor downward, which would also lower the AOA of the rear wing. And, since it will be more difficult to seal the diffusor, dropping it should improve its performance. They would have to insure it doesn't stall though, otherwise the cars would loose a large amount of the downforce from one second to the next - very dangerous! It shouldn't be a problem to circumvent the rules...
FW17
171
Re: 2014 Design
fake airbox looks horrible.
avatar
avatar
Re: 2014 Design
Re: F-India image
What's going on with the wheel nuts?
Are they plastic, painted mat grey, or did someone get the texture wrong in a CG render?
Re: 2014 Design
looking at the entire image, the latter is most likely.
Re: 2014 Design
I think the nose might be like this:
Tourgott
Tourgott
Re: 2014 Design
I'm not sure if you guys already know it but the German magazine "auto motor sport" asked Charlie Whiting if those three noses would be legal and he said yes.
Whiting: "I don't know if they would pass the crash test but I would say yes they match the rules."
Source: http://www.auto-motor-und-sport.de/form ... 97594.html
Re: 2014 Design
Charlie didnt read the rules :lol: :arrow:
Holm86
249
Re: 2014 Design
Blackout wrote:Charlie didnt read the rules :lol: :arrow:
apparently not. The "Caterham" has a single central pylon. As far as I know thats not legal.
