Yes, three valves per cylindere were not uncommon. Two inlets and one exhaust. You call the Dolomite , 14. Never heard of it as that. There was a Dolomite 1500, 1850 and then there was the Sprint, with the 16 valve head. Not a bad engine, but overheating was aleways a problem, as with the Stag. Had a 1500 once, and also a Stag.marcush. wrote:unfortunatelly the 16V head was only available for the dolomite I4 so the stag could only be build in a V8 24V version...has anyone build something as weird as that?..I had a TR7 Convertible a long time ago ..as it broke a piston .I learned a bit about this particular piece of engineering..
marcush. wrote:sorry foul wording..
Dolomite sprint was the 16V engine..
I meant stag V8 with one bank 2 valve and one bank as 16V... thats weird..
again..not the best words i chose..the Dolomite 16V engine is based on the V8 stag engine.As for the Stag theres only 8V heads ..but the dolomite shares borespacing bolt pattern etc you could actually mount one 16V head on a stag engine..I´m not aware if someone really did it.sorry .donskar wrote:marcush. wrote:sorry foul wording..
I meant stag V8 with one bank 2 valve and one bank as 16V... thats weird..![]()
Do I understand you to say that the Stag V8 had two totally different head designs -- one with 8 valves and the other with 16?
On the same engine?
As a mechanic back in the 1960s I learned a great deal of disrespect for English auto engineering, but that one is really way out there!
McLaren is automotive since they have split with MB to pursue their own sports car brand.747heavy wrote:Since when is McLaren producing F1 engines. I guess, it´s easy to have an opinion on it, when you are not the one, who need to built the engines.
I did not question, that they are an automotive manufacturer.WhiteBlue wrote:McLaren is automotie since they have split with MB to pursue their own sports car brand.747heavy wrote:Since when is McLaren producing F1 engines. I guess, it´s easy to have an opinion on it, when you are not the one, who need to built the engines.
Turbo lag is a thing of the past! There was no problem with lag, in the previous turbo era. Constant pressure with electronic control of revs eliminates it. And as for a 3.8 V8 twin turbo only producing 600 bhp. Are you serious? The old 1.5 single turbo fours, were giving 1500BHP.godlameroso wrote:Because getting 600ps from your average 2.0 4 banger takes roughly about 32psi, which means you need a hell of a blower, which means stupid turbo lag. Your engine would need to be able to rev to 9,000rpm to have any sort of usable power band. You wouldn't hit full boost till around 4,500rpm, and that's using every trick of the trade to reduce turbo lag.
I still think it's better to use a 3.8 V8 twin turbo to make 600ps than it is to use a 6.3L V12.
At 9000 Rpm, 32 psi (1.2 Bar boost) for 600 Hp from 2.0 litres sounds about right, regardless of number of cylinders.gilgen wrote:Turbo lag is a thing of the past! There was no problem with lag, in the previous turbo era. Constant pressure with electronic control of revs eliminates it. And as for a 3.8 V8 twin turbo only producing 600 bhp. Are you serious? The old 1.5 single turbo fours, were giving 1500BHP.godlameroso wrote:Because getting 600ps from your average 2.0 4 banger takes roughly about 32psi, which means you need a hell of a blower, which means stupid turbo lag. Your engine would need to be able to rev to 9,000rpm to have any sort of usable power band. You wouldn't hit full boost till around 4,500rpm, and that's using every trick of the trade to reduce turbo lag.
Seemed huge to me as well but that's what one of the ex drivers,,I don't remember for sure which said and if you ever saw them run in anger it's believable ,,I don't remember the total boost but it was equally shocking.Holm86 wrote:4 bars at idle? dont believe that....
