Team: Stefano Domenicali (TP), Mario Almondo (Director of Operations), Aldo Costa (TD), Nicolas Tombazis (CD), Luca Marmorini (HE) Drivers: Fernando Alonso (5), Felipe Massa (6)
Beautiful closeup composition pic!
I'm surprised by
A) the seam in that area of the chassis...never noticed it before or recall seeing one there on any of the other cars
B) the amount of joint gap at top.
Is that just a body panel joint? It certainly can't be a tub seam.
hardingfv32 wrote:I think they have been weak all season. They get a win because the competition has a bad pit stop and/or is possibly operating with less than an optimum engine setting.
It was a good win for the team/driver, but hardly evidence that the car has improved.
Brian
i think you are wrong my friend
what hardingfv32 said is absolutely right
not really. Ferrari might not be faster than the Bull, but they're getting damn close and with Alonso that's close enough to compete. In Silverstone, once the track dried out, Alonso was the fastest man on the track, every site has said that even PlanetF1. If the the most biased of all the British F1 sites can admit the Ferrari has gotten quick why can't you? Does it really bother you that bad to see Ferrari's upgrade plan working. Is it Ferrari or Alonso that gets to you?
I'm surprised by
Just a thought regarding the gap at the top, if say there was some form of a flexible joint there, could this be a way to get the whole nose to bend and lower the front wing?
Nah, remeber the 2001 ferrari i think it was that broke in half while being driven by is wealthy private owner in america some where? I recall talking about it in a thread about a year ago and a person in the know explained that ferrari actually have a seam in the tub there that they use in the building process. rarther than a top and bottom molded tub. BUT apparently its usually filled and sanded to show no seam. wonder why? Quick part turn around time maybe? Anyone know if its a new tub?
Also if you think about it, if it were to flex i would say the tea tray is more likely to hit the deck rather than bring the nose down.
One thing i did notice about ferrari in all 3 practice sessions was how low the front wing was. touching under braking in some places! Again you could pull the old redbull BS and say its set up, but i still feel if the height of wings and other apendages should be measured from ground level and not baseline/wheel centerline ect
Caito wrote:I don't know if it has been discuseed but, does anybody know why ferrari runs such rear anti roll bar?
As I see it, instead o transmitting motion to the ARB they're transmitting force due to the compression of those springs.
But, why?
It's a dual rate ARB. One rate till the spring is compressed, then another rate.
PhillipM wrote:What I can't work out is why they are using two spring/damper units instead of just 1 unit, which would be lighter?
no dampers in the ARB springs, but you need two torsion bars and two dampers one for each wheel
