So the V6 will be more of an engineering challenge than an I4 in terms of fuel efficiency.
That to me confirms that they have made the right choice by going for the V6 format.
So isn't a v6 a perfect compromise, in a sport completely about compromise? A v4 would be in your words more rigid, so of course a 6 will be. it will also be a shorter engine, important in a sport where they are mounted in line with the vehicle, not longitudinally.Whiteblue wrote:
That is great news!!! We are going to have progress with the engines eventually. I don't really mind that they mandate a L4. It is not so short and rigid as a V4 but should be very efficient friction wise.
Extremely tenuous I'm afraid. It's well know that V engines have a more torsional stiffness regardless of whether you get something 'made to your requirements' and it is just inherently more compact. It is what it is.WhiteBlue wrote:You simply have to specify the stiffness and the designers will optimise the shape in stressed or semi stressed design to your requirements and you can choose whatever fits your preferences better.
[youtube]http://www.youtube.com/watch?v=xanOeYcQpcM[/youtube]n smikle wrote:The V6 has more friction as said above... what else makes it less fuel efficient? Accelerating a larger rotating mass I presume?
I remember reading an article on website saying that V6 are not made below a certain displacement for the reasons above. The friction power becomes a larger portion of the losses as the dimensions go down. That's why we don't have V8 lawn mowers.Interesting still.
That only goes to prove that people will go to any length to say that their mower is better : I've witnessed "lawn wars" syndrome beforeflynfrog wrote:*youtube video of V8 lawnmower*
It is not only the friction, the thermal efficiency also suffers due to bigger heat exchange surfaces. And despite the contrary posts you also have more manufacturing cost, weight and space for the V6 engine.n smikle wrote:The V6 has more friction as said above... what else makes it less fuel efficient? Accelerating a larger rotating mass I presume?
