Formula E
Big Tea
99
Re: Formula E
jjn9128 wrote:
20 May 2018, 16:42
nzjrs wrote:
20 May 2018, 13:32
That's really a fantastic video. He's really pushing and learning the limitations/difference/quirks in real time.
Agreed! You would have thought he'd do his homework beforehand though :lol:
But he is playing, not job hunting :D
roon
roon
412
Re: Formula E
In that video, at 0:22, during take-off, the pulsations. Are these traction control? Drive train harmonics? Tire slip?
strad
117
Re: Formula E
Sorry
Guess I misunderstood. :oops:
Sir Stirling Moss
jjn9128
779
Re: Formula E
roon wrote:
20 May 2018, 18:37
I assume it's just the sound of the motor at low revs while he tries not to run over the photographers.
#aerogandalf
Big Tea
99
Re: Formula E
jjn9128 wrote:
20 May 2018, 20:21
roon wrote:
20 May 2018, 18:37
Does this new car have re-gen?
Just realised, they are linux. Gen2
jjn9128
779
Re: Formula E
Big Tea wrote:
20 May 2018, 20:29
Definitely - it's the major benefit of the electric drive train, they wouldn't get rid of it!
Gen 2 because it's a spec bodykit. I think it's technically called the Spark SRT05-E but that doesn't roll off the tongue so well :lol:
#aerogandalf
strad
117
Re: Formula E
Interesting race from Berlin.
Sir Stirling Moss
MattyT
MattyT
Re: Formula E
roon wrote:
20 May 2018, 18:37
I've driven an electric kart which does the same thing at low revs, so it's definitely not TC, but I don't have a more technical explanation of it unfortunately
Big Tea
99
Re: Formula E
jjn9128 wrote:
20 May 2018, 20:58
Big Tea wrote:
20 May 2018, 20:29
Was wondering if Nico's foot was not firm enough and the re-gen was unsure if it was in or not.
jjn9128
779
Re: Formula E
Big Tea wrote:
21 May 2018, 14:22
I thought the re-gen was requested from a paddle on the steering wheel - so they lift and coast with no foot on either pedal, then pull the paddle for re-gen, then brake with the left foot. That he wanted the brake bias backwards maybe suggests he wasn't using the re-gen at all - that's not really an issue for a 5 lap demo run though.
You can have re-gen when lifting off the accelerator as a lot of road EV's do, but that means you can't coast. You could also have it as the 1st stage on the brake pedal, but if you hit a bump and end up braking it's not ideal.
#aerogandalf
Big Tea
99
Re: Formula E
jjn9128 wrote:
21 May 2018, 14:31
Big Tea wrote:
21 May 2018, 14:22
I was trying to think why the surge when Nico eased out of the box, with people all around him. I remember first driving an EV and did the same thing. Too little peddle and the 'system' was confused and juddered in and out of drive/recover.
(this was in the early days of EV though)
jjn9128
779
Re: Formula E
Big Tea wrote:
21 May 2018, 14:37
Ah yes my bad, regen wouldn't try to kick in without the paddle being pulled either way.
If you try to use a power drill really slowly with some load you'll get a similar juddering. I imagine it's to do with the rotor/stator positions - rather than a smooth transition you can feel the jump from pole to pole.
#aerogandalf
Steven
Owner
Re: Formula E
I have asked Brembo about the specification of the brakes for the upcoming car. This is their response:
As regards FE at the moment we can’t release details about the system of the next season.
So we know the diameter is identical at the front to F1, but I asked for clarification on thickness, calipers and brake material.
J.A.W.
J.A.W.
109
Re: Formula E
Steven wrote:
21 May 2018, 19:30
Good on you, Steven - for showing the gumption to make some enquiries at source, as proper fact checking.
It seems - on face-value - curious that the disc diameter dimension is identical, given that FE discs are not constrained
by a much smaller rim diameter, unlike other Formula series..
So it may well be an 'economy of scale' factor in effect, with an 'off-the shelf'' brake package specification from another,
lesser, Formula series set-up (which indicates a similar braking performance requirement) - & likely* not F1..
* You never know, though, since even if FE cars require only a fraction of the braking performance demanded by F1,
Brembo may have been requested to provide FE with an 'F1 spec' braking system for reasons of 'prestige marketing',
which could - perhaps - trump 'merely technical' requirements - in certain circumstances.
djos
113
Re: Formula E
Considering FE cars are electric, the goal would be to harvest as much energy as possible under braking via the motors operating in re-gen mode.
As a result having the brakes built to F1 spec would be extremely wasteful.
When F1 introduced the current PU regs, the F1 teams all reduced the size and performance of their rear brakes in order to capture as much energy as possible via the MGU-K under braking and remove excess weight that was no longer required.
"In downforce we trust"
