...I think they'll go for a repeat of the 2006 approach of driver name on the sidepod...though I'd prefer numbers, if only to avoid having an F1 car with "Kevin" on the side..!!
Agreed. KMag would be cool although it wouldn't work in JB's case.adrianjordan wrote:Ooo....that looks good. I wonder if they'll have a quick livery launch or whether they'll just roll out in FP1 with the new livery...
I agree it is designed to be part of the impact structure and is doing an important job, I was just trying to compare it to the main impact structure behind which will take far higher loads. I just worded it badlyPer wrote:Good spot on the stiffener that you marked in orange. At first I thought the change in colour on the inside was just the edge of a piece of carbon fabric, but then I saw the discontinuity in the reflection on the outside of the tip, at a very similar height, indicating the presence of a stiffer zone. Well spotted.
I don't agree that the green section is not load-bearing. I really don't see any kevlar fibres either. On the contrary, the honeycomb in this section is clearly visible in the ruptured area near the top right corner of the AMuS watermark. I think the top and bottom half of the tip have equal dimensions, also because I don't see a reason why they wouldn't have. At the front edge of the bottom section no honeycomb is visible but this is probably the same on the top. The reason is it is difficult to incorporate honeycomb in a section with high (double) curvature, like the very tip of the nose.
In fact, the presence of the stiffener you spotted is the best proof that the tip does carry some load in case of impact. The stiffener prevents the sidewall of the tip from buckling as a whole, keeping deformations more in-plane and increasing energy absorption. Don't be distracted by the low thickness of the composite facesheets. It is not difficult to design a 2mm thick CFRP plate that has a maximum compressive load of 1000N/mm. Of course this is an impact structure so it is designed to fail at a much lower load but it doesn't mean it does nothing.
I agree that it is kept very light though (mass very far away from C.o.G. so it adds a lot to yaw inertia) and in higher speed impact the part starting at the FW mounts will do most of the work.
Side On Pic from Sutton Images. The side pods look different from testing..Thunders wrote:Ok here we go. First Pictures from Melbourne via AMuS.
The "Mobil1" an the Guys shirt plus the Chrome Color on the Headrest lead me to believe that these are McLaren Sidepods. Which would mean a new Livery with more Black.![]()
http://img4.auto-motor-und-sport.de/Imp ... 763002.jpg
Edit: On closer look it seems to be totally different than the Sidepods at the Pre Season Tests. One straigt Arc whereas the "current" MP4/29 has lots of curves. Weird.
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
Yes they are....C'mon MCL give us some nice shots of the Mp4-29 with the new livery ... [-o<Thunders wrote:They're teasing soo hard.
Unless something has changed, Mclaren doesn't believe in putting decals/stickers on its cars.Xero wrote:I'd guess the stickers have yet to be placed on them?
Stickers...mclaren777 wrote:Unless something has changed, Mclaren doesn't believe in putting decals/stickers on its cars.Xero wrote:I'd guess the stickers have yet to be placed on them?
Everything is painted.
What are those small holes for, have they always been there?Lucky wrote:on the other hand
http://img4.auto-motor-und-sport.de/McL ... 763405.jpg
