Red Bull RB10 Renault
chuckdanny
chuckdanny
69
Re: Red Bull RB10 Renault
jagunx51 wrote:
chuckdanny wrote:I discovered a knew vortex that passes through the inside of the rear wing endplate
http://oi61.tinypic.com/2vigm7k.jpg
do you have the original pic ? thanks
This one is better, the original gives not much more and it's 18mb
chuckdanny
chuckdanny
69
@bhall
very interesting way of approaching the problem, i would basically understand that the less you disturb the air, making it to work for your own purpose that is creating downforce hence as a by product upwash only and not sidewash.
chuckdanny wrote:i would basically understand that the less you disturb the air, making it to work for your own purpose that is creating downforce hence as a by product upwash only and not sidewash.
You can't create downforce without disturbing the air. Sadly, the method that gives least drag is the one that the teams can't/won't play with - the methods they do use (wings, brake duct flips etc.) make downforce and disturb the air a lot whilst doing it.
The open wheels don't help either...
chuckdanny
chuckdanny
69
that's what i said, the purpose is creating downforce that is downward momentum in equilibrium with reaction forces from the tires and the byproduct of this is inevitable upward momentum of the air what i call upwash, which of course is a big disturbation of the air. But you don't need to work the air laterally so sidewash is a byproduct without benefits ! Well that's not completely right because they use sidewash at the bottom of the sidepod and with the front wheels endplate for exemple to protect the upward and downward facing faces of the diffuser from the dirty air coming from the front wheels but that's the general idea. For the rear wing placed further up you don't need sidewash, it's of no practical use. PLus, you could benefit from an upstream sidewash that would bend downstream to fill the void created by the three plane device that create massive downforce at the rear, diffuser, rear wing and flap and because the relative depression at the back coming from this general movement is generating drag.
Most sports car use lateral air to fill the gap behind because to let it be filled by the air coming from the roof has a negative effect in term of overall downforce. I mean think of the general form of a car above ground, it's basically a wing facing in the wrong direction that is creating the opposite of downforce. A car that would have half the form of a drop of water at the back and straight sides like walls without bending would be a nightmare in term of downforce except if you work the air with a rear wing because it's the general profil of an extrados.
I've split off the "air to bodywork energy transfer" topic: http://www.f1technical.net/forum/viewto ... 12&t=19178
It is a very interesting discussion indeed, so I recommend all participants to continue on there.
gandharva
252
CottrellGP
CottrellGP
Red Bull RB10 with conventional RWEP louvers in Spain
Dan Cottrell
Master Of Innovation!
Sophisticated louvres I have to say. They very much resemble stacked wing elements. I wonder if this actually creates a bit of downforce on its own when in yaw.
gandharva
252
Seems like they are not going to run a bigger exhaust pipe like merc or ferrari.
gray41
Mercedes have tweeted that they won't be using the new exhaust until the post race test.
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
Spain 2014 - Thursday (08.05.2014)
gandharva
252
Spain 2014 - Friday (09.05.2014)
gray41
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
RicerDude
27
Wonder what the Zebra print is Made of. Fur would be too heavy and slippery.
