agip wrote:Downforce levels should be keeped. That's what makes F1 unique from the other racing series. They just need to reduce drag a LOT. So less turbulence + nose to tail races = more overtaking.
I also think that is the final aim, so why not stop trying to achieve it indirectly and tackle it in the most direct way possible?
I'd propose something like:
* take a wind tunnel capable of working with two 100% size cars and label it "the official one"
* take the winning car of each season
* set your proposed design in the official wind tunnel, and last year's winner right 2m behind it
* your design is valid if:
- it is deemed safe
- the tracking car shows XXX tonnes of downforce or more
the main issue this would raise is that each package should have to be tested before it can be used at a race, thus delaying the introduction of design innovations, but, still, it may be worth it
(maybe having a permanent FIA ambassador at each manufacturer's reduced-scale wind tunnel instead of using a single official wind tunnel can iron out this problem)
