We usually see garage pics on Thursdays, so I'm expecting some, just a little later than usual do to the time difference. [-o<JohnsonsEvilTwin wrote:Ahhhh Dren,
Im eager too! I can almost make out the longer wheelbase!![]()
Pics today do you think?
The intakes do look smaller. They were larger because the roll bar/structure is larger at the front and was at the front of the intake. Now they are moved back to where it comes to a point. The sidepods look more undercut (hard to tell if they really are because the back of the bodywork isn't attached), the sidepod wing is shaped different, the front brake cooler intakes look different.horse wrote:I can't believe there is a direct drag reduction from moving the air box intakes. They must have the same cross sectional area, after all. So it's either some downstream effect (possibly less interaction with the rear wing) or another trick to get the aerodynamic balance a little further back.
http://www.autosport.com/news/report.php/id/83340
