Ferrari SF1000
holeindalip
holeindalip
Re: Ferrari SF1000
jjn9128 wrote:
23 Nov 2020, 20:14
holeindalip wrote:
23 Nov 2020, 19:54
jh199 wrote:
18 Nov 2020, 18:22
https://cdn-6.motorsport.com/images/mgl ... tail-1.jpg
Here's a nice image from motorsport.com showing a vortex formed underneath the floor
Where does this vortex form? The leading edge of the floor behind the barge boards?
There's a horizontal delta shaped vane on the step plane - inside the "bargeboard" volume. I've seen it called the "water wing". You can see it forming here
https://www.totalsimulation.co.uk/wp-co ... rticle.png
https://encrypted-tbn0.gstatic.com/imag ... w&usqp=CAU
pierrre wrote:
14 Nov 2020, 16:56
interesting picture...that jet of water making away around that standing vertical blade(whatever they call it)
Generally called the SPLEF - Side Pod Leading Edge Flap
Yup that’s what I thought, I think I was just calling it something different.... Thank you
gordonthegun
254
Re: Ferrari SF1000
Huge cooling exit on the rear of Ferraris in Bahrain.
Low power but high cooling needs. :?
https://it.motorsport.com/f1/news/f1-te ... uVqZk9z9jg
zibby43
zibby43
Re: Ferrari SF1000
gordonthegun wrote:
26 Nov 2020, 23:12
warpomex
warpomex
Re: Ferrari SF1000
zibby43 wrote:
27 Nov 2020, 01:32
gordonthegun wrote:
26 Nov 2020, 23:12
https://cdn-1.motorsport.com/images/amp ... tail-1.jpg
Is that a volute in the exhaust pipe? Interesting...
Re: Ferrari SF1000
Jolle
Jolle
133
Re: Ferrari SF1000
gordonthegun wrote:
26 Nov 2020, 23:12
Those two go together. Because of the fuel flow limit, the more power you make, the less cooling you need.
wowgr8
wowgr8
29
Re: Ferrari SF1000
Mammoth hot air exits this weekend. I remember last year at Bahrain they brought decently tight/small exit engine covers at this same track
zibby43
zibby43
Re: Ferrari SF1000
wowgr8 wrote:
27 Nov 2020, 17:17
And it’s cooler this time of year.
aleks_ader
90
Re: Ferrari SF1000
Jolle wrote:
27 Nov 2020, 14:06
gordonthegun wrote:
26 Nov 2020, 23:12
Also less tight blockage - less drag. I mean less internal drag. But in expense of losing some corner performance. But relatively speaking they more need compromise in minimal straightline speed losses than pure corner perfomance. Also track is not so much curvy hence their decision to run that setup.
wowgr8
wowgr8
29
Re: Ferrari SF1000
zibby43 wrote:
27 Nov 2020, 19:36
Yeah I really don't know what to believe, there was (and still is) talk of the radiators in the sidepods creating a blockage that hampers airflow and creates drag (though apparently that was just put out by Ferrari through the media as an excuse for the bad performance on the straights), but it seems there's actually an issue with the cooling, they haven't run the exits tight once this year. The "normal" config in 2020 is like the hot race config in 2019
TechF1
Re: Ferrari SF1000
wowgr8 wrote:
27 Nov 2020, 22:12
zibby43 wrote:
27 Nov 2020, 19:36
It's always the same problem, more fuel flow less cooling needed. Most of the problems comes from there, they're just trying to cover the engine due to their reputation, but the problem it's just there.
In 2021 we will see almost the same car going way better.
ScrewCaptain27
577
Re: Ferrari SF1000
Small FW update. Footplate has been cut and a small flick added, similar to Racing Point.
- Serj Tankian
Re: Ferrari SF1000
Different FW configs for Sakhir GP
Schippke
Schippke
Re: Ferrari SF1000
You would think Ferrari would trim as much downforce as they could for this one to have any sort of chance of being competitive on the straights... the term 'sitting duck' springs to mind.
Re: Ferrari SF1000
Morteza wrote:
03 Dec 2020, 16:16
https://pbs.twimg.com/media/EoUZ-69XEAc ... ame=medium
Bottom wing isn't new but hasn't been seen in a long while.
