Mercedes W11
dans79
267
Re: Mercedes W11
Sieper wrote:
20 Jul 2020, 17:48
Cosworth was just an engine supplier not also the dominant team (that just copied their car for another team as well that is now also top 3 to say the least, might be top 2 as well).
Don't forget this is the customer car period, so a large chunk of the grid ran duplicate or almost duplicate cars, or one or two season old models.
201 105 104 9 9 7
Hoffman900
Hoffman900
219
Re: Mercedes W11
dans79 wrote:
20 Jul 2020, 18:01
Sieper wrote:
20 Jul 2020, 17:48
dans79 wrote:
20 Jul 2020, 17:22
I was just about to point this out as well. It reminded me a bit of Indy Car before they went to a single supplier chassis.
F1Krof
95
Re: Mercedes W11
I'm sure you guys have seen it before, but I've just noticed this for myself.
Source:
Wroom wroom
Re: Mercedes W11
The modern car is a feast of detail. Simply eye watering detail.
Re: Mercedes W11
OO7 wrote:
19 Jul 2020, 00:56
Zibby, the car doesn't touch the kerbs at all during 0:22 and 0:35. At 1:00 there's a pretty clear separation denoting the sound from the car and the sound from the kerbs.
The farting noises is the engine tuning system working its magic. It is similar to the Honda step-firing. Cutting some cylinders or adjusting of timing to fire a bit late, i think respectively saves fuel or used to quick spool (blow down energy). It is not considered traction control because it doesn't use a feedback loop from the wheel speed sensors to do this. It is baked into the engine map from the garage.
I noticed the car doing this honda-like noise in winter testing, but was told it was already doing this from before.
zibby43
zibby43
Re: Mercedes W11
OO7 wrote:
19 Jul 2020, 00:56
Must be a more subtle sound then, are you listening with headphones?
F1Krof
95
Re: Mercedes W11
Can somebody explain this please?
https://www.formula1.com/en/latest/arti ... GJ2TZ.html
What is the difference between this (W11)
And this (W10)
Wroom wroom
Re: Mercedes W11
See where the leading leg of the lower control arm is? Right beside the driveshaft. It must pushed rearward. The trailing leg is also far back.
Compare redbull
Re: Mercedes W11
There is also that it has been raised relative to the previous one, I think. That's helped free up space above the diffuser to help airflow.
Re: Mercedes W11
One of the few things where it's immediately clear what it's purpose is and where you can see how it improves performance.
Xwang
Xwang
29
Re: Mercedes W11
PlatinumZealot wrote:
21 Jul 2020, 01:56
OO7 wrote:
19 Jul 2020, 00:56
I haven't had time to check it, but I was sure that traction control systems were outlawed by requiring a kind of unique growing function between the pedal position and the power output (or demand).
Was I wrong?
63l8qrrfy6
63l8qrrfy6
368
Re: Mercedes W11
Cylinder skipping still delivers whatever torque the driver requests. The difference to normal firing is that there are fewer cylinders operating at higher load. The mean torque at the wheel is the same.
Re: Mercedes W11
MtthsMlw wrote:
22 Jul 2020, 11:07
It also looks like it turned into a multi-link suspension. The lower control arm is actually two separate arms now.
Mchamilton
Mchamilton
Re: Mercedes W11
Mudflap wrote:
22 Jul 2020, 13:31
why would they ever do that?
dans79
267
Re: Mercedes W11
Mchamilton wrote:
22 Jul 2020, 17:13
Mudflap wrote:
22 Jul 2020, 13:31
Most likely fuels savings and reduced heat.
201 105 104 9 9 7
