Thank you to all contributors for succeeding where the FIA didn't!
Apart from mclaren_mircea.
To me it seems as the still can fit a monkey seat. I didn't find something ruling it out.whiteblue wrote: [*]no monkey seat
matt21 wrote:To me it seems as the still can fit a monkey seat. I didn't find something ruling it out.whiteblue wrote: [*]no monkey seat
WhiteBlue wrote:Just to summarize the discussion the FiA was referring to a plan for a massive change from a flat and stepped floor towards tunnels. That one is not going to happen. But there are other detailed changes that in total bring a relatively new aerodynamic configuration.
The sum of those things amount to the biggest aero change since many years. So the publication of the FiA is a bit misleading although it has some truth in it regarding the change of floor concept that is not going to happen.
- low noses
- narrower front wings
- different side pots
- different engine length, height and width
- different air intake rules and forced induction
- different exhaust rules, position and single end pipe
- no monkey seat
- no beam wing
- new tyre construction with different deformation
There is no body work allowed between 150 and 750 mm vertically as Huntresa's source points out nicely in graphics. This is in contrast to 400mm-730mm today. Where do you think the monkey seat should go?matt21 wrote:To me it seems as the still can fit a monkey seat. I didn't find something ruling it out.whiteblue wrote:[*]no monkey seat
I think the 15cm on the baseline is an exception.WhiteBlue wrote:There is no body work allowed between 150 and 750 mm vertically as Huntresa's source points out nicely in graphics. This is in contrast to 400mm-730mm today. Where do you think the monkey seat should go?matt21 wrote:To me it seems as the still can fit a monkey seat. I didn't find something ruling it out.whiteblue wrote:[*]no monkey seat
You still have the mdidle centimeters free even without beamwing, so you could put a monkey seat on the crash structures top level, if its workable to attach like that.WhiteBlue wrote:And where do you suppose to have your diffusor?
Well, there will still be 2 banks of 3 exhaust pipes exiting the engine, but they both will be connecting to turbo which will have one exhaust pipe exiting it. So, that is basically one exhaust pipe that exits the car in the middle above gearboxHuntresa wrote:Also i think they reverted to having 2 exit pipes on the exhaust but exit will be where we have monkey seat today pretty much and no real way to not have it there.
Huntresa wrote:You still have the mdidle centimeters free even without beamwing, so you could put a monkey seat on the crash structures top level, if its workable to attach like that.WhiteBlue wrote:And where do you suppose to have your diffusor?
Are you sure? With the beam wing gone, where would they mount the rear wing?WhiteBlue wrote:The central green exclusion zone is gone.
