The only time I've seen an image like that was with the previous Caterham/lotus car.R_Redding wrote:Spain 2013 - Friday (10.05.2013)
On the FP1 coverage at 21:40 ish
The CT-03 was going down the main straight with Kovalainen in the seat and you could see a white vortex coming off the barge board area and tucking underneath the car ,running down the side of the plank to the diffuser.
Not normally seen but the camera angle and elevation allows it.
Rob
Can anybody retrieve that image?R_Redding wrote:Spain 2013 - Friday (10.05.2013)
Rob
I hope somebody gets that image so people can see what we're always trying to describe.shelly wrote:Can anybody retrieve that image?R_Redding wrote:Spain 2013 - Friday (10.05.2013)
Rob
Certainly – I always thought that was meant to be one of the main goals of a barge board – to create the vortex that pulled air under the floor rather than around the side of the car. The other goal is to pull what doesn't go down under the car around the side ofc.R_Redding wrote:It started at 22mins
http://img546.imageshack.us/img546/5241/ct03vortex.jpg
on the video you can see the vortex swirling around .... I'm not too sure what this indicates
Is it correct...are they doing it deliberately?...
Isnt it the same new wing ran in Barca?wesley123 wrote:Addition of a small cascade on the new wing(lower in the pic)
That wing only ran the larger cascade iic, this one has a small one next to itHuntresa wrote:Isnt it the same new wing ran in Barca?wesley123 wrote:Addition of a small cascade on the new wing(lower in the pic)
The top one is the new front wing.Leendert82 wrote:Stevan,Which one is the new front wing, the top of the bottom one?
