Edis wrote:No, you don't want to reach 125,000 rpm as soon as possible as that would force the compressor into surge as a centrifugal compressor can't supply pressure unless there is adequate flow and the flow depends on how much air the engine can use (engine speed, throttle position and so on). The turbocharger speed needs to be controlled depending on what boost level you want to reach, where a higher boost pressure in general means a higher turbocharger speed. So, if for instance the boost pressure is lowered at engine speeds above 10,000 rpm due to the fuel flow limit it is possible that you need to reduce the turbocharger speed above that point.
From a purely turbo point of view I would agree. But the MGU-H is driven by the turbine also.
So we have two loads applied to the turbine Compressor and MGU-H
Power generation from the MGU-H is unlimited in the regulations. Boost is unlimited in the regulations, but is effectively limited by the fuel flow at about 2.75 Bar and mass air flow <1500kg/hr. As power is a function of force over distance and in the case of a generator torque applied over rotational speed, we can either apply high torque to the turbine at a lower speed or low torque at a higher speed. There will be a compromise of where in the scale of MGU-H tq/rpm gives the least backpressure to MGU-H benefit.
My thinking is, the work done by the turbine should favour the unlimited output-MGU-H. The turbine can have a finite amount of load applied before losses from increased back pressure exceed the gains from MGU-H.
Could the Turbine be sized where it makes up to 125k rpm at 7krpm engine speed or even at part throttle. In normal circumstances the compressor will surge, but if we bleed off excess mass air flow we could prevent surge. Yes there will still be load applied to the turbine by this work done, but there may be a balance to be had where total load applied to the turbine is less than the gains from MGU-H generation.
I am just theorising here and the 125k rpm may not be attainable, but I believe there will be a balance to be had, which will be forever changing with load and engine speed, where MGU-H power might take priority over compressor function and in the case of too much boost, then that could be bled off in order to prioritise MGU-H function?
