SectorOne wrote:I´d like to see this:
- Teams get 100kg´s of fuel to use for Qualifying and Race. How they use that is entirely up to them.
- Engine manufacturers can not charge more then 5 million and they have to accomodate any team wanting to buy their engine.
- Virtual box of dimensions where the engine has to fit exluding exhaust.
- No rules on electric harvesting, storing or deployment. Only certain safety regulations aimed at mechanics and driver.
If rules like these are good or not i have no idea but i do think they give a lot more freedom rather then "it has to be a V8 with a cylinder bore of yada yada yada"
It´s a bit like the laws of nature in that if you want to build an airplane the only criteria is that it needs to be able to fly.
You don´t have to build an exact replica of a Boeing 747 to build an airplane.
So price, fuel allocation and outer dimensions are the only limitations, other then that you can do whatever you want.
+1
I would just limit fuel for the race otherwise qualy is going to be lots of cars sitting in garages
Otherwise, FIA to supply up to 100kg of pump fuel for each car for each race.
Limit size of cars to a box
Mandatory safety requirements
Minimum driver and seat weight.
Then a Balance of performance to ensure one team isn't miles ahead and to allow manufacturers to bring their own tech. I.e. maybe Renault want a small turbo engine and Ferrari want loads of cylinders, balance it out at the end so that they can both be competitive.
As much as I hate BOP I would rather have a strong healthy grid full of cars with plenty of differentiation .
