> There are 3 Ferrari powered teams.
To be fair there are 2 teams running 2017 Ferrari engines, one running the very well understood 2016 version not serving up useful data.
Is there an hydraulic heave damper on this Maca ?GoranF1 wrote:Mclaren starts to work on the car now...
https://twitter.com/piusgasso/status/836178832575119361
Just wanted to highlight the gap in performance they create vs. 2016 specs. Achieving the same lap time with an almost 20% deficit in top speeds is quite an achievement. Given the additional cornering speed (which makes them quicker at the straights as well) and increased PU Power (which helps to run different gear ratios) i would rather think about top speeds in the 320km/h region at best lap time level. I believe they will hit these speeds for sure.Diesel wrote:What makes you think they are coasting? Considering the additional drag this year, is 330km/h likely? I think not...ForMuLaOne wrote:If the top speeds reported at f1.today are accurate we are about to see massive times. Vettel is doing 1.22,791 at a top speed of 279.7km/h. That´s insane if you consider 2016 times ( all around 1.22 ) were with top speeds well above 330km/h.
So teams are setting serious times while coasting down the straights. I am curious where we will end up today, knowing that teams are not even thinking about going quick.
2017 might become very cool again =D>
He's not really pushing, not much acceleration out of the corner. Looks very smooth though, but it is just a testing program, not qualy laps.
I think he wants to be first in the lunch queue!Anthropolyte wrote:Bit of a brown trouser moment for Magnussen - he's planted the Haas in the barrier. Only a couple of minutes after the guys on Autosport said it looked "stable"
Er he's been running softs all day, Ben.11:30 A Mercedes on softs - this should be a bit more interesting...
