Alfa Romeo C38
Owen.C93
Owen.C93
177
Re: Alfa Romeo C38
Isn't that a comparison between this and least years wheel, rather than driver to driver.
ESPImperium
ESPImperium
64
Re: Alfa Romeo C38
After many years of the Ferrari steering wheel, no wonder Kimi wants a simple layout, as this was his Ferrari wheel from last year:
Simple layouts are better, but require more learning. My preference would be the McLaren wheel, however i do hear that there is a 44 page manual to it, and a simulator that can be taken on an aircraft for a driver to use with his engineers on the flight, most teams have this these days as i remember in 2017 that Brendon Hartley used 5 hours in the flight to navigate the STR wheel.
At least is isn't the Audi R18 e-tron quattro as it has a 128 page manual, a wheel simulator and an interactive test to do, that's what Allen McNish and Tom Kristensen both said in 2015 in the Le Mans coverage. Back then they were comparing Hulkenbergs wheel in the Porsche 919 Hybrid to the Force India wheel back then. McNish said that the old V8 era F1 wheels only had a 8 page PDF that got emailed to you, and called them a simple but expensive toy to a LMP wheel, even though they all cost circa $50,000 a wheel, probably $15,000 more now.
Wheels are a deeply personal thing, look at Hamilton when he went to Mercedes, he ditched 30% of the functions on his wheel, and went with a much more visual and colour based design to what Rosberg had. Less bull, more driving.
Re: Alfa Romeo C38
Owen.C93 wrote:
22 Feb 2019, 23:25
Yes it's a comparison between the 2018 and 2019 steering wheels.
No need for an ice cream button IMO, it must be automatic.
sri1031raj
sri1031raj
-1
Re: Alfa Romeo C38
cplchanb wrote:
22 Feb 2019, 17:00
no ice cream button???? :lol:
joke is becoming stale now, but when thre is so much difference in steering buttons, will Kimi not miss some options
Big Tea
99
Re: Alfa Romeo C38
I know telemetry reply from the pits is not allowed, but is spoken commands from the driver? Cortana style?
roon
roon
412
Re: Alfa Romeo "2019 Contender"
In roll, the anhedral* front wing elements might provide more downforce to the inside wing, and less downforce to the outside wing. Static, the lift vectors are seemingly skewed something like 15 deg from vertical. As the car rolls, the angle of the inside front wing's downforce vector will reduce more favorably to vertical. 14 deg? 13 deg?
*Or is it dihedral? Since this is negative lift.
Dihedral in aircraft is associated with stability. Could there be a similar consideration here?
Another thought: Can this be considered an inwash wing? I know it's been brought up here. A big change in philosophy if so. The Y250 vortex will be the main one forming off this wing. The endplate vortices will be so small in comparison. It makes me wonder if most of the flow off the front wing will get pulled inside or over the front wheels. Due to the strength of the Y250 and the weakness of the endplate vortices.
Morteza wrote:
14 Feb 2019, 14:03
Also of note in this photo is the rear wing slot gap. It varies.
dtro
dtro
Re: Alfa Romeo C38
Is it possible that the Alfa/Ferrari style front wings are trying to accomplish something similar to what the notches in the floor by the rear tyres are trying to accomplish, namely sealing the the front wing/attempting to deal with tyre squirt in a different manner?
Probably way left field here, but that's why speculation is fun.
roon wrote:
24 Feb 2019, 00:34
This shape makes the y250 stronger, and the outer edges guide air flow in a more brute-force way than the vortex made by the outwash tunnel(although there's still a vortex involved). It uses the end plate to try to steer the airflow so that it can interact with the front wheel at a certain angle.
Well known meterology fact, tornadoes, which are just big ass vortecies, are caused by rising airflow interacting with strong shear winds. The tire is a spinning shear current generator, so if you get the vortex to hit the wheel at a certain angle interesting things happen. Like for instance at one angle the vortecies will split into smaller more stable but weaker vortecies, at other angles, they can even be strenghtened, with the downside that they're less stable to perturbations.
Or maybe they're just trying to combine the vortex made by the end plate foot plate, and the outer edge of the wing, as they're at similar height with regards to the tire. Helicity between 2 co-rotating vortices increases their strength.
bill shoe
bill shoe
151
Re: Alfa Romeo C38
ESPImperium wrote:
22 Feb 2019, 23:53
https://i.imgur.com/n3WWSiT.jpg
I can't help notice that in this high performance environment, there are no touch screens. Many knobs and buttons, but no touch screens.
Yet on the public roads people are using touch screens all the time and (in the U.S. anyway) the accident rate (fatalities per mile) is going up again for the first time since the modern safety revolution started in the ~60s.
F1 has much to teach the world about road safety here, but we ignore it and worship at the (touch screen) altar of Steve Jobs. Until we hit the light pole.
cramr
cramr
Re: Alfa Romeo C38
bill shoe wrote:
26 Feb 2019, 02:08
ESPImperium wrote:
22 Feb 2019, 23:53
Of course. For a touch screen you need to look what you press. With buttons and knobs most of the things can be done by memory and without looking. Hence faster
ESPImperium
ESPImperium
64
Re: Alfa Romeo C38
bill shoe wrote:
26 Feb 2019, 02:08
ESPImperium wrote:
22 Feb 2019, 23:53
Exactly, its safer to have a physical button or rotary then have a touch screen. Touch screens are great, but in an automotive role they are the devil and are unsafe and high risk as you are continually adjusting on them.
And a touch screen can suddenly reboot, where as a button or rotary has a much lower failure rate.
Sometimes the best tech is simple, and sometimes the most simple tech is the most high performance. Link that with ergonomics and the human brains need for visualisation, and familiarisation, and memory.
Re: Alfa Romeo C38
Via AMuS
F1NAC
172
Re: Alfa Romeo C38
Raising Merc game
Godius
186
Re: Alfa Romeo C38
Re: Alfa Romeo C38
