Ferrari SF21
gastonmazzacane
Re: Ferrari SF21
Fer.Fan wrote:
11 Mar 2021, 18:44
I have a question: how much more cdf time has ferrari got due. 6th place last year?
Is it huge differens compared to top three teams?
Source: https://www.formula1.com/en/latest/arti ... dYx8a.html
santos
santos
Re: Ferrari SF21
There's a yellow circle above the VISTAJET logo and under the Shell logo. It wasn't there in the pictures, yesterday. What is it?
Owen.C93
Owen.C93
173
Re: Ferrari SF21
Telemetry connection.
TechF1
Re: Ferrari SF21
santos wrote:
11 Mar 2021, 18:50
There was some sort of carbon plug before, i could suppose it's a engine connector i don't know it's use.
FWandE
FWandE
Re: Ferrari SF21
TechF1 wrote:
11 Mar 2021, 19:02
santos wrote:
11 Mar 2021, 18:50
https://i.imgur.com/pKfLOLM.jpg
It's where they insert the crank handle to start the engine :lol: :lol:
bucker
bucker
Re: Ferrari SF21
Giando wrote:
11 Mar 2021, 10:22
bucker wrote:
11 Mar 2021, 10:16
cplchanb wrote:
10 Mar 2021, 15:55
How can they not use any tokens for the nose??? It's been modified quite heavily similar to alfa Romeo.
Tokens are for non aero surfaces.
So, the actual crashbox hadn't been modified at all and there's bodywork around it, which is what we see from the outside, right? sort of a double layer
edgelo
edgelo
Re: Ferrari SF21
Sevach wrote:
11 Mar 2021, 18:39
wowgr8 wrote:
11 Mar 2021, 18:23
No T-Wing?
They darkened all the important areas before putting the picture up. The area of the sidepod where the shell logo is located definitely looks more bulbous than it did last year, I guess this had to be done if they were going the Red Bull route with the crease and trying to make use of the coanda/downwash effect. The area where the "ray" is located looks collapsed into the car, eyeballing it I can't tell whether it's slimmer than last year's, I thought they did a great job last year
They and Aston have gone in different routes trying to achieve the same goal with the sloping sidepods, we'll see what solution prevails
The "crease" between sidepod and engine cover is a lot more obvious now, very Red-Bull esque.
The "Ray-Ban" was previously located in an area where sidepod and top of the engine mashed together, now it's solidly on the engine, sidepod is pretty much over, the "UPS" last year was close to straight up, now it's part of the ramp.
Not sure about the "Shell", might be a little wider as you say, but the reduction behind it is worth it i think.
All that with the fact that the sidepod shoulders also got more rounded (again straight out of RBR design style).
I think so. Ferrari goes Red Bull esque, and AM is more like a green Mercedes.
On the AM, the sidepod and the engine cover seems slopes whith a valley between them. And the vertex leaving a channel above the undertray.
IMO this solution (AM/Merch) will cause a little more drag, but higher downforce from the diffuser. Otherwise, the Ferrari/RB do the opposite (it has to go higher rake to increase downforce).
Marble
Marble
Re: Ferrari SF21
f1316
f1316
80
Re: Ferrari SF21
I’m probably reading WAAAAAY too much into the specification run on a filming day... but, isn’t that a fairly big rear wing for Bahrain? Could that be a sign of confidence in the engine power this year?
LM10
LM10
121
Re: Ferrari SF21
f1316 wrote:
12 Mar 2021, 00:25
It’s always a combination of power and drag and according to Binotto they managed to improve both to the point that straight line speed won’t be a problem anymore.
C Plinius Secundus
C Plinius Secundus
Re: Ferrari SF21
Hi, a little question, has anyone seen any picture of the car on which you can see the diffuser? All the pictures I've seen have that area of the car digitally obscured... #-o Thanks.
jacques96
jacques96
Re: Ferrari SF21
C Plinius Secundus wrote:
12 Mar 2021, 01:25
https://ibb.co/b2R0Z1t
I found this...
Re: Ferrari SF21
f1rules
f1rules
588
Re: Ferrari SF21
Re: Ferrari SF21
