Haas VF-22 Speculation Thread
Re: Haas VF-22 Speculation Thread
I really like the slope & shape of the nose... Hope it stays the same... :D :D
west52keep64
51
Saw this on racingnews365.com. It really shows how far forward Haas have pushed the sidepods:
Original article here: https://racingnews365.com/how-does-the- ... 2-show-car
wowgr8
wowgr8
29
F1Krof wrote:
09 Feb 2022, 08:04
Blackout wrote:
08 Feb 2022, 21:11
Can you guess which arm is the steering rod?
https://i.imgur.com/W4bzSwQ.jpg
This feels very odd somehow. Something doesn't add up here. Just intuitively looking at it, I believe the real version of the car is more akin to this:
https://i2.paste.pics/FXSLS.png
The sidepod inlet shape looks normal. I mean that's what it looked like on the W10 before they lowered the upper SIPS in 2020, and lowering the spar is not possible under these new rules so of course the inlet goes back to the old shape
timbo
timbo
111
All the more respect to Haas
bauc
timbo wrote:
09 Feb 2022, 22:11
Amen to that =D>
AeroDynamic
349
west52keep64 wrote:
09 Feb 2022, 13:39
https://s3-eu-west-1.amazonaws.com/raci ... 1644060556
brightened is nice
JPower
JPower
43
timbo wrote:
09 Feb 2022, 22:11
Agreed.
Even a render of an older design evolution is far better than a livery model.
jjn9128
779
west52keep64 wrote:
09 Feb 2022, 13:39
Nobody was going to use the FOM inlets
#aerogandalf
While everyone talks about the suspension, no one notices how you can see the edge wing through the sidepod undercut. :?:
AtlasZX
Looking at the fake "movable" piece on the 4th element, i was wondering if this could be a 60% wind tunnel model.
CMSMJ1
CMSMJ1
AtlasZX wrote:
10 Feb 2022, 07:15
Looking at that - where does the lower main plane mount? Just missed it from the render, or am I going to clean my specs?
IMPERATOR REX ANGLORUM
Giando
93
CMSMJ1 wrote:
10 Feb 2022, 13:04
AtlasZX wrote:
10 Feb 2022, 07:15
I pointed that out in a previous post. It's attached (or integrated in the mould) to the side plates, so it creates an interesting flow space under the nose tip. It could also flex a bit under air pressure at high speed i guess.
Giando wrote:
04 Feb 2022, 15:22
Render or not, there's something interesting in the front wing area.
The structural part of the front wing attached to the nose cone is the first flap, the red one (or maybe a combination of the first, second and third) which then sustains the side vertical rounded panels... so the bigger main profile of the front wing is kind of suspended between the side panels and never touches the nose cone.
https://postimg.cc/bd3p3TH4
CMSMJ1
CMSMJ1
Giando wrote:
10 Feb 2022, 13:08
CMSMJ1 wrote:
10 Feb 2022, 13:04
AtlasZX wrote:
10 Feb 2022, 07:15
Giando wrote:
04 Feb 2022, 15:22
Thanks Giando - so do you reckon that the main plane is actually suspended then from the second plane?
It's surely not just hanging from the slot gap seperators? Imagine a T1 nudge of someone's tyre...the whole lower plane will detach?
basti313
basti313
CMSMJ1 wrote:
10 Feb 2022, 14:00
Giando wrote:
10 Feb 2022, 13:08
CMSMJ1 wrote:
10 Feb 2022, 13:04
Giando wrote:
04 Feb 2022, 15:22
I think this whole design leaves a lot of room for tech talk.
From the point of crash prone and disassembling I would say that the "new" location is much better. Carbon fibre is well flexible, so if they hit someone the first flap will flex. So as in the past the whole wing will go, but much later if they have contact in the middle.
Flexing the front wing flaps will still be a core point of development, this is where Merc excelled last year, in the Merc the whole stack of flaps just bend away. If I am not mistaken the test procedure is still static weights on the sides but maybe all flaps and see if it flexes down. If they now just hang the wind on the second flap, this is much more easy to get the wing out of the wind by rotating it and still have the lateral stiffness to pass the test.
Don`t russel the hamster!
godlameroso wrote:
10 Feb 2022, 06:00
