I do not fully agree with you. Yes the cost of the car is high but most of it is development. Making carbon parts is not so difficult. A lot of companies are able to do them at quite low cost (especially in Chine), and with GOOD quality (at least as much as original part) !marcush. wrote:don´t be naive...
each F1 car produced by Wirth set Virgin back 1.5Mill€ (wirth was speaking of the equivalent of less than a Bugatti Veyron)it was reported.
And that´s a f1racer designed with costlimitations very high on the agenda.
to even think of keeping a reasonable stock of spares -reproduce them - would be commiting ecomonmic suicide.If you can get some surplus ,fine ,but reproduce parts is just not feasible .This is a 750 headcount producing 5 chassis per year type of car...think about the workhours that went into it to produce and run it.
this is at least comparable to keeping military aircraft airworthy...
Any major off with this (in case you get even near to running it) or any fault in terms of correct proceedures will potentially render the thing effectively a writeoff due to the cost to bring it back to life after destroying expensive components.A very good step would be to try and find its sistercars and purchase what you can get hold of just to have a remote chance to not run out of importanat parts.
Having the part 3D modeled is not so difficult either, just be careful and 100% committed with it and it should be ok ! Otherwise there is still the laser machines that can help you but it would cost a lot more. Of course I'm not talking about redo a chassis, but small parts which may subject to break after a contact with barrier or something.
