Comparison of all 2011 cars
FW17
171
Re: Comparison of all 2011 cars
Why are todays cars look so bulky in the mid section. Engineers have been working every year to obtain a tighter packaging but still when you look at early 90's they look bulky in comparison.
Here below is a lambo 291, a v12, trans gearbox and a full race fuel tank yet look at the size of that thing in comparison to todays cars (comparison based on pictures only, actual data not available) but comparing the height of wheels and side pod that car is sleek
Discussions in the other threads on the max airflow to the beam wing, but this car puts all of them (specially Mclaren) to shame
halllo_fireball
halllo_fireball
Just think of safety - these old sidepods won't be much help in the event of a side crash.
shelly
shelly
136
Also 1991 cars were much wider (max width 2150 instead of 2000 from 1993 and 1800 from 1998), with larger track width and larger tyres, so in comparison bodywork seems smaller and sleeker
twitter: @armchair_aero
kakogohrena
kakogohrena
Re: McLaren MP4-26 Mercedes
bot6
bot6
The angle of the car is different, so it's hard to take anything from this...
Richard
Richard
That's a bad comparison. We need to be sure they are at the same point on the track with the same photographer. We also need to see both airboxes and rear wings at teh same time because they are at fixed identical heights.
Darren Heath has done that, he says these two pics are the same place and came camera angle ... the pics are gone - curse twitter!
ianwit
ianwit
I don't think its too far out, check out the position of the four wheels in relation to each of the cars, only the furthest wheel away is slightly out. Considering the speed of the cars and the vagaries of photography I reckon its a remarkable match up.
Became a McLaren fan in the late 70's when I ended up laminating their Kevlar nosecones.
Mchamilton
Mchamilton
i dont think the rear wings are at fixed heights, the rear wheels of the 2 cars line up pretty well yet the red bull rear wing is considerably higher.
the cars are at almost identical angles too going by the rear wheel rim.
the left end of the mclaren front wing is lower than the red bull yet the right side of the red bull is lower by at least twice the amount.
the red bull is running more rake and we know the mclaren runs very stiff, so the red bull would pitch into the corner more than the mclaren.
from the head on pictures that have been posted on the web the mclarens wing flexes considerably more than the mclarens anyway..
forty-two
kalinka wrote:Interesting comparison. I didn't realise until now how much higher is the RBR's nose is. Also it seems the driver position is considerably higher too. I'd say at least 4-5cm.
What's that vertical ridge that going across the top of the dissuser and continuing down under the crash structure ? What's the purpose of it? It looks like it's directly in way of the airflow...or it's just some kind of optical illusion :wtf:
I'm not sure I know what you mean by vertical ridge.
There is a gurney flap running along the top trailing edge, but that is quite standard. The only other thing I think you might mean is approx halfway between the trailing edge and the driveshaft where the "scoops" of the diffusor begin, and I think that this is an optical illusion, but it could be something tasty?
I think it's probably the angle of the picture, but the gurneys either side of the crash structure seem to be asymmetrical to me?
shelly
shelly
136
roll hoop cameras are mismatched by some cm.. I reckon it si difficult to find a better alignement for comparison
kakogohrena
kakogohrena
RB7 chassi and driver realy higher 3-5 cm. Here is another comparison, right side
hollowBallistix
hollowBallistix
this is a much better picture !
the nose & front wing look about the same height in this picture, what is amazing though is how low Button is compared to Vettel, considering Button is taller !
pete555
pete555
The advertising board grows when the red bull passes too :shock: .
The zoom must be different or picture taken closer in.
I don't think you can attribute any accuracy in dimension using the slider.
bot6
bot6
Like Pete said.
Mchamilton
Mchamilton
pete555 wrote:The advertising board grows when the red bull passes too :shock: .
i think you'll find wheel rims are fixed size and the rear wheels match perfectly :P
